oil leak under intake?
jvandyke
PostPosted: Tue Jun 13, 2017 2:15 am    Post subject: oil leak under intake? Reply with quote
pulled engine again, for belts, release bearing, pilot bearing and to chase an oil leak, evident dripping from front, suspect front main but noticed oil actually pooling on block fins under the intake, maybe the filler/breather tube leaking? I doubt that's the source of the oil finding it's way to dripping off the front bottom (under the crank pulley area and all along the crossmember) but maybe.
Really would like to hedge bets and get this leak with engine out but not 100% sure I want to do ALL possibilities, like all the balance shaft seals and all, but now's the time I guess, thoughts?
87 924S project, '83 944 engine,
my son's first car.
PostPosted: Tue Jun 13, 2017 1:05 pm    Post subject: Reply with quote
The steering rack and its hoses can be the source of the mess on the cross member.
hdrider19
PostPosted: Tue Jun 13, 2017 1:24 pm    Post subject: Reply with quote
I pulled my engine out of an 84 944 so I am in the same boat as you. When I pulled it out both balance shafts were leaking so bad that if I tilted the engine in any direction oil would run out the front or rear. Also the orings on the air/oil separator were shot.
87 924S
jvandyke
PostPosted: Tue Jun 13, 2017 10:52 pm    Post subject: Reply with quote
so the balance shaft housings were leaking?, I am pretty ignorant yet, I assume you can tear down the housings and reseal, we're doing belts anyway and engine is floating in the breeze so if parts aren't insane, now's the time I would think, now to figure out what bits we need
my son's first car.
PostPosted: Wed Jun 14, 2017 12:29 am    Post subject: Reply with quote
I did an engine-out reseal in 2014. Read up on all of the procedures on Clark's garage, the garage manual section, print out each 'job' as you do it. I tore the engine down to just the pistons and crank. Replaced the rod bearings, and 1200 dollars later (which included all of the gaskets/seals and water pump), it was back in the car! It developed leaks after that in spite of my best efforts. The front main seal is tough to reseal, as well as the oil cooler, the balance shaft covers, and the oil pan.
Also, if pulling he head (my oem gasket was not a pretty sight!), you can clean out the coolant passages around the piston sleeves. And, if not replaced yet, time to replace the sensors on the bell housing.
Once you clean the block, and take apart the engine, the intimidation factor lessens! Take a lot of pictures if in doubt, keep everything clean.
jvandyke
PostPosted: Wed Jun 14, 2017 7:02 am    Post subject: Reply with quote
my kid is NOT going to want to tear it down that far, he's long since out of money, we'll see how far I can talk him into going
my son's first car.
jvandyke
PostPosted: Wed Jun 14, 2017 8:53 am    Post subject: Reply with quote
and those too are a leaky mess, but we have oil quite badly
I'll get the engine secure on a stand and take some pictures
my son's first car.
PostPosted: Thu Jun 15, 2017 12:16 am    Post subject: Reply with quote
About 110,000 miles worth:
hdrider19
PostPosted: Thu Jun 15, 2017 12:24 am    Post subject: Reply with quote
A bottom end gasket set would get you most of what you need to fix all the leaks. You can find them on ebay for about $180. I used a Victor Reinz set on mine. Very good quality.
87 924S
jvandyke
PostPosted: Fri Jun 16, 2017 11:04 am    Post subject: Reply with quote
fighting the crank pulley bolt
engine on stand, scheming of a way to lock flywheel
impact guns aren't touching it...
anyway.....
wondering about the caps on the rearward ends of the balance shaft housings, both are "loose" and the exhaust (lower) one leaks oil while on the stand, the engine did get a little sideways during removal and transfer from hoist to stand so oil may have moved around a bit but I'm curious is they're supposed to wiggle when you touch them
I guess that's a sign of a worn seal....
Pelican is out of the kits, another good source? Can't find on ebay either. Thoughts?
AutoAtlanta has a kit but I don't like those guys, they seem to always screw it up
my son's first car.
hdrider19
PostPosted: Fri Jun 16, 2017 1:01 pm    Post subject: Reply with quote
Are you searching 83 944 for engine parts? Here is a link to a gasket set. Same one I used on mine.
http://www.ebay.com/itm/New-Victor-Reinz-Engine-Gasket-Set-Engine-Block-944-100-901-01-/391794598073?fits=Year%3A1983%7CMake%3APorsche%7CModel%3A944%7CSubmodel%3ABase%7CEngine+-+Liter_Display%3A2.5L&hash=item5b38c720b9:g:GWUAAOSw~FJZJo88&vxp=mtr
Make sure all parts are for 83 944. There are differences. This applies to timing parts also.
The crank bolt is torques to 165 ft lbs. it is stubborn. You might need a bigger gun.
87 924S
jvandyke
PostPosted: Sat Jun 17, 2017 7:42 am    Post subject: Reply with quote
I could not find that set for love or money.
Since I piece mealed a bunch of that already I think I'll just get the balance shaft seals from Pelican, alhtough they are out of hte upper front seal, have to here for that I guess;
http://www.ebay.com/itm/Porsche-924-928-944-968-Engine-Balance-Shaft-Seal-Left-Upper-NEW-999-113-282-40-/151810903144?fits=Make%3APorsche%7CModel%3A944&hash=item2358a28c68:g:3jkAAOSwFnFV8Vm~&vxp=mtr
We got that bolt out, (is it reusable? or do you replace it?, threads look okay not really "sharp" towards the end)
I made a flywheel holder and a breaker bar and a huge sledge hammer and it came out, I have to believe that was put on with much more than 165ftlbs
my son's first car.
jvandyke
PostPosted: Tue Jun 20, 2017 1:55 pm    Post subject: Reply with quote
end caps on balance shafts were really loose, oil has been pouring out of one as it sat on the engine stand for the last few days (it was slightly askew)
We tore both balance shafts down and the rear o-rings were crazy loose.
We're doing balance shaft rear/front seals and front main.
I'm a little worried about how this came out (front main) does this lip okay? did it flip over on install? is that bad? or normal?
my son's first car.
