hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Tue May 16, 2017 12:40 pm Post subject: Sunroof repair help? |
Does anyone know the best sunroof repair thread? My drive cable is hooked to the motor still but it is pulled out and runs around the taillights and spare tire. The micro switches are loosely mounted and I think the long curved gear on right side is missing. My sunroof needs lots of help. I have found threads on the gears and the clutch but I need something a little more in depth to solve all the problems.
Thanks Paul _________________ 87 924S |
edredas
Posted: Tue May 16, 2017 1:52 pm Post subject: |
I've been meaning to make thread on this for a while now but haven't had the time... I'll try to help you the best I can.
What usually happens is over time the slip-clutch doesn't slip like it should... even if the micro-switches are mis-adjusted, it should just slip. Instead it strips the gears and rips the cable out, like what you've described.
So, what you're going to need to do is feed the cable back through and order new gears. Then you'll need to adjust the slip clutch first and set the micro-switches.
Let me know if you need any more info and I'll try to guide you through it. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
hdrider19
Posted: Sun Aug 27, 2017 11:57 am Post subject: |
I am looking for the right side lift arm(long curved gear). Mine is missing. Anybody have one you would sell? I pulled the motor out and reinstalled the cable with a healthy coat of grease. Then I found out the cam is broken where the cable attaches. Ordered an aluminum one from Only944. Going slow but making progress. _________________ 87 924S |
hdrider19
Posted: Mon Aug 28, 2017 10:37 am Post subject: |
Yes,please. If you can find a spare I would love to buy it from you. _________________ 87 924S |
Posted: Mon Aug 28, 2017 11:10 am Post subject: |
I'll look in the morning when I'm at my shop. _________________ White 87 924S "Ghost"
Posted: Tue Aug 29, 2017 6:30 am Post subject: |
No luck finding one, went through a dozen or more tubs of parts so far. _________________ White 87 924S "Ghost"
hdrider19
Posted: Wed Aug 30, 2017 11:36 am Post subject: |
Thanks for looking. _________________ 87 924S |
