Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Fri May 12, 2017 5:06 am Post subject: Recirculation valve/ BOV which way ? |
As I am running a 944 turbo I use an axternal recirculation valve/ BOV (from Forge).
On the internet I see two differant way's to mount it (boost in/out), is this the correct way or doesn't it matter ?
 _________________ 937 trackday car
Posted: Sat May 13, 2017 1:34 am Post subject: |
Don't need a dump valve. Run a closed system  _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sat May 13, 2017 3:46 pm Post subject: |
The original turbo also has a built in recirculation valve/ BOV. Because the 944 turbo doesn't I use the Forge external one. _________________ 937 trackday car
Posted: Sat May 13, 2017 6:51 pm Post subject: |
Pressure in from below. Pressure out at the side. Vacuum/boost signal above. Forge say do not reverse the flow. Is that a pic of your forge BOV ?
Try it with and without BOV. They aren't always needed. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sat May 13, 2017 7:12 pm Post subject: |
ok, thanks so the pictue is telling it wrong
The picture above is not my recirculation valve but it looks simular, this is the Forge I use:
