81VIN452 Guest
Posted: Wed Sep 11, 2002 5:50 am Post subject: |
Hi to everyone, I just left the parking lot this afternoon, driven for 1/2 mile, stopped at the gas station, refueled, started, no noise, no errors, 2nd gear won't engage. It looks like it had never existed, the notch removed. I had to drive 20 miles, crossing the town, jumping from 1st to 3rd and viceversa. Has anyone heard of,or experienced a similar problem? I'm terrorized about the cost to tear down the tranny, and really hope is a minor common inconvenience for a well kept 931 with manual trasmission and 90,000 km. I will really appreciate everyone's help.
Thanks, Ignazio. |
Pat Guest
Posted: Wed Sep 11, 2002 9:07 am Post subject: |
I had the same problem with first in my 80 924 turbo, after I took apart the gearbox I found that the 1st gear dogteeth were completely worn away and the synchro ring had expanded and woudn't allow the shifter to move into the gate. I hope it isnt your problem but I cant think of anything else that would account for the problem ( the transmission was a snailshell, or 16/Z or G-31 whater you want to call it). |
clhughart Guest
Posted: Thu Sep 12, 2002 2:29 am Post subject: |
Take a look at the shifter. We had this happen but it was first and second in our case. The shifting rod that comes from the transmission up to the shifter has a round hole just below the shifter. The shifter has a "bolt" or steel rod that goes through this rod. As you move the shifter front to back and from side to side, it "bolt" is supposed to twist the shifting rod. In our case, the "bolt" had become worn so that it wouldn't twist the shifting rod. The fix was simple; I just took out the shifter, welded some material on the "bolt" to restore it back to the original shape. To see if this is your problem, take off the rubber boot, and move the linkage to see how it works. Then take something you can wedge inside the hole of the shifter to take up any slack and see if it will shift into second. I hope this is your only problem. |
Lizard Guest
Posted: Thu Sep 12, 2002 6:23 am Post subject: |
at this point it is probably your syncro your easiest option at this point is to probably just get another tranny although being in italy that is probably going to be hard eh #### it just do it yourself
