What are the AFR ratio's you want for a 931 ?
Goto page Previous  1, 2
PostPosted: Sat May 06, 2017 7:05 am    Post subject: Reply with quote
I can confirm that the AF allen screw does change the overall mixture, not just the idle mixture.
The plugs on my 931 were grey/white...that's lean and the idle was lumpy.
I adjusted for more fuel and the plugs are brown + black...idle is steady and pedal response is improved.
I have to get a wideband kit for this car as well soon.
red 924 and not red 924
PostPosted: Sat May 06, 2017 6:27 pm    Post subject: Reply with quote
But it will be linear through the whole range. Rich idle means super rich at WOT. The WUR is the place to change idle mixture from top end. Boost enrichment device is where you can manage mid range when coming on boost.
Or go EFi
PostPosted: Sat May 06, 2017 11:13 pm    Post subject: Reply with quote
Yeap, that's right.
I'm going to install EFI on my red 924...not sure weather this year or the next...but I do plan to in the near future.
PostPosted: Sun May 07, 2017 6:07 am    Post subject: Reply with quote
Idle is now about 14, on boost also arounnd 14.
Cruise stays about 17. Is that a problem ?
937 DITC
PostPosted: Sun May 07, 2017 6:57 am    Post subject: Reply with quote
Idle and cruise should be 14.7 or slightly richer. Wot on full boost should be 12 or richer. Most stock 931s will be circa 10 to avoid det
PostPosted: Mon May 08, 2017 9:57 am    Post subject: Reply with quote
Something is definitely amiss. I would start by looking for air/boost/vac leaks in the intake tract. You should be getting a steady 17Hg of vacuum on fully-warmed-up idle. If it's less, you have a leak somewhere and need to find it.
Page 2 of 2
