how to disconnect door wiring connectors
ted von Kampen
PostPosted: Sat Apr 15, 2017 9:04 am    Post subject: how to disconnect door wiring connectors Reply with quote
The drivers door on my 924 has 3 wire harnesses that come out the bottom of the door and go into the pillar. In the pillar cavity there are 3 connectors that link these wires to the main harness, etc. The 3 sets control the electric mirror and power windows. I want to replace the rubber boot in the door. One of the connectors is round and presented no problem getting apart. The other two are flat. One with several wires and one with 2 wires. I can see no part line to get the connectors apart. The plug is marked VW and is the original harness. I can see through to the connector pins but cannot see how to separate. Any suggestions?
