Exact OD of 931 Down Pipe
PostPosted: Fri Apr 14, 2017 1:47 am    Post subject: Exact OD of 931 Down Pipe Reply with quote
Por favor. Gracias.
PostPosted: Sun Apr 16, 2017 12:59 am    Post subject: Reply with quote
Rasta
If nobody answers this before me, I''ll get it measured. A 931 is on the lift plus I have a few downpipes lying around. One of the very reasons its on the lift is do redo the downpipe and exhaust.
1982 931 parts car or resurrection?
PostPosted: Sun Apr 16, 2017 2:06 am    Post subject: Reply with quote
Assume you mean the front pipe coming off the turbo? 60mm
PostPosted: Sun Apr 16, 2017 3:18 am    Post subject: Reply with quote
...and that is a kooky number for what we have access to over here. 2.36"
57mm is basically 2.25" so at our 2.5", easy to get tube, we are at 63.5mm and 3" is 76.2
Its harder to get 2.75"
PostPosted: Sun Apr 16, 2017 4:08 am    Post subject: Reply with quote
Inches seems like a scale for agricultural applications
Non metric stuff is silly....you can count all of those 60mm if you want to..but how will you count the 2.36 inches?
red 924 and not red 924
PostPosted: Sun Apr 16, 2017 4:45 am    Post subject: Reply with quote
I've been fighting the connection between the downpipe and the rest of the system ever since I got this car. There is a "slip fit" there now, with a clamp on it, but it's loose.
Suggestions welcomed. I've been browsing some racey clamp setups, etc, trying to find a good solution.
PostPosted: Sun Apr 16, 2017 6:33 am    Post subject: Reply with quote
Morghen- We are stuck with non metric even though I like working in both. Maybe its because I have to most of the time. If we get speed limits here in kph they will just lower the speed limit. For that reason I'll stay non for now
Rasta - why not try something like this? Just v-flange and call it a day Edit: Cheap ebay OBX or other works just fine but personally I like the ones that have a pilot lip. It centers everything and it seals up nice
I made this for an experimental exhaust for my BMW.
WEASEL149
PostPosted: Sun Apr 16, 2017 6:48 am    Post subject: Reply with quote
I constantly have to convert from metric to imperial/inch and vice versa. Units are just units after all.
Counting 2.36" reasonably accurately, just use thousandths@2360.
1979 UK 932
Kenodog
PostPosted: Sun Apr 16, 2017 8:32 am    Post subject: Reply with quote
Ridiculously simple fix. Have a machine shop turn a step spacer from 60mm to 2.5" nominal. Tig weld the spacer to some 2.5" pipe and away you go. In the future all necessary bits will be common to N. America 2.5" stuff.
Me
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
1996 Dodge Caravan (DJV)
PostPosted: Sun Apr 16, 2017 8:53 am    Post subject: Reply with quote
Never had an issue with my slip joint. Snug fit and coated with loctite high temp gasket sealant.
https://www.flickr.com/photos/16693103@N03/8321038043/in/album-72157629431377585/
PS this set up has been made redundant by a custom front section
