Leaky part
thelloyd
PostPosted: Thu Mar 16, 2017 6:32 am    Post subject: Leaky part Reply with quote
Car has been running great, popped the hood to check oil and saw a small pin hole stream of fluid coming from a hose. Anyone tell me what part the arrow is pointing to so I can order? Thanks
PostPosted: Thu Mar 16, 2017 6:40 am    Post subject: Reply with quote
You are not going to have fun! The fuel and return lines run up the firewall and you'll need this kit. Verify with the company, like call them, to make sure the hose kit will fit the 924S. The fuel pressure regulator and damper on the early 944 is back by the firewall. So, the hose to the fuel damper will be short on the 924S. You should replace the 'crossover' fuel line as well, about 100 bucks for one of those!
http://944online.com/index.php/air-fuel-system-65/early-944-fuel-line-repair-kit.html
hdrider19
PostPosted: Thu Mar 16, 2017 8:06 am    Post subject: Reply with quote
I replaced the fuel hoses on my 924S. Here is my thread about the fuel lines.
http://www.924board.org/viewtopic.php?t=42477
87 924S
wrenchesandswearing
PostPosted: Fri Mar 31, 2017 6:22 am    Post subject: Reply with quote
By the car gods! Are those lines made of angels tears?!
The more I look into repairing my 924s, the more I'm considering swapping the engine for a reconditioned. I knew I was getting into some expensive territory, but... yikes!
If at first you succeed, failure is imminent.
1987 924S - A heap of a project
