Mreed1
Posted: Thu Aug 11, 2016 11:58 am Post subject: Oil in 924 turbo intake. |
I have 1980 924 turbo in which I just had the turo rebuilt. I'm getting oil in the intake and it smokes while running. It's hard to start the engine while cold. Sometimes that will run well for a long period of time and then have a warm hard start problem. Any suggestions? |
macBdog
Posted: Thu Aug 11, 2016 12:16 pm Post subject: |
Classic aging 931 issues right here, you've come to the right place. Plenty of other members will have a crack at diagnosis but to kick it off in reverse order...
Warm engine hard start: Check the fuel accumulator at the rear of car near the gearbox.
Cold engine hard start: Check cold start valve and WUR
Smoking out the tailpipe after turbo rebuild? Leakdown test, oil getting past rings and into intake. _________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways |
Posted: Thu Aug 11, 2016 12:22 pm Post subject: |
Sounds like multiple separate problems..
Look for vacuum leaks and fix them all, if you are planning to keep the car just replace all the rubber vacuum elbows and hoses..
Do a CIS test, you will have to get or make a CIS tester..
As far as the oil in the intake, that sucks.. You could maybe try running it in for a little longer hoping the intake side piston rings on the turbo seat themselves, or make em rebuild it again.. idk
iirc it is not unheard of for a freshly rebuilt turbo to leak oil like that.. _________________ 80 Turbo - Slightly Modified |
Posted: Thu Aug 11, 2016 2:05 pm Post subject: |
Smoking while running may have nothing to do with the turbo. It could very likely be worn valve stem seals (moderate difficulty to replace, can be done with engine in situ) or worn/broken piston rings (best to pull the motor for this one).
Difficult warm start: for an engine that has been fully warmed up and running within the last hour or so, the owners manual calls for depressing the accelerator all the way to the floor, and then starting. You may find that this solves the hot start problem. If it doesn't, it's best to get a CIS tester and go through this regimen to isolate the problem. The accumulators are frequent culprits, but there could be multiple compounding problems, so best to be highly methodical when troubleshooting the CIS.
Difficult cold start: can be caused by any number of the CIS components: failed cold start valve (CSV), failed thermo-time switch (TTS; tells the CSV when and how long to spray), failed wiring between TTS and CSV, failed or stuck auxiliary air valve (AAV), failed warm-up regulator (WUR), etc. For general troubleshooting, follow the regimen here, which covers most of these issues and more.
Welcome to the forum. Keep the questions coming, I'm sure the crew here can help you get it running reliably! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Aug 11, 2016 5:58 pm Post subject: |
Put a bore scope in the spark plug holes when cold and see if there is wet oil pooling in the Pistons. This would indicate valve stem oil seals leaking. This is indicated by oil smoke on start up but gone once warmed.
Compression test to see if the bores/rings are worn. Results should be within 10% of each other. Piston #3 and #4 are usually the culprits of bust rings. Worn or snapped rings with cause oil smoke at all times especially on revving and under load.
These engines do breath oil vapour. The design of the breathing system draws positive pressure in the crankcase through the Purolator and turbo and into the intake manifold. Even a good engine will have oil mist in the system. A bad engine will have oil pooling in various spots. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
macBdog
Posted: Fri Aug 12, 2016 2:05 am Post subject: |
Rebuilt turbo on a worn motor will smoke due to crankcase pressure interfering with turbo oil drainage. This is bad for the turbo, as are the combustion gasses in the crankcase. Ask me how I know!
2nd the broken ring hypothesis. _________________ Toofah King Bad
Mreed1
Posted: Sat Feb 18, 2017 10:52 pm Post subject: Oil in 924 turbo intake. |
Checked the compression and all around 120 psi. Still have oil in intake and plug fouling after run up. Could thr seals on the rebuilt turbo be leaking? |
Posted: Sat Feb 18, 2017 11:32 pm Post subject: |
You need to do a leakdown test on the cylinders, as the compression test only gives you a moment-in-time reading. The leakdown test will tell you if air is bypassing the rings. 120PSI sounds low to me. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Feb 19, 2017 1:57 am Post subject: |
14.7 x 7.5 = 110.25
120 sounds fine to me. _________________ Toofah King Bad
Posted: Tue Feb 21, 2017 9:45 am Post subject: |
I remember a case where a 931 had the wrong dipstick and was overfilled with oil..... _________________ White 87 924S "Ghost"
