Shurick's 931 build
Goto page 1, 2, 3, 4, 5, 6  Next
Shurick
PostPosted: Wed Jul 22, 2009 2:38 am    Post subject: Shurick's 931 build Reply with quote
The car:
S1 931 ROW spec (M31.01 engine), snail-shell (G31.01) gearbox.
The goal:
Reliable daily driver with some descent performance. Five days a week to the work and two days for racing.
The way to reach the objectives:
- EFI&EDIS based on Abit 9.2.4 engine management system (yes, I like that version number!);
- CGT-spec turbo;
- FMIC with waterspray;
- Boost control by Abit EMS;
- Upgraded suspension;
- 951 brakes;
- Partially removed and lightened interior.
Mods already done:
Custom intake with side mounted throttle body. The reason not to go for a S2 intake was clearance issues and length of plumbing.
Pictures and some additional info can be found here: http://www.924board.org/viewtopic.php?p=250147
Got a fully rebuilt turbo K26-2664G6.91. In coupe with 931 exhaust housing and Blitz SS BOV it fits without any additional mods (pics will come soon).
FMIC is used from Mitsubishi Evo8 with some mods in caps and outlets to fit in front of radiator. It was selected as the best of the cheap parts available. It flows good for 240-290 hp, having a bit higher capacity then the 951 unit. The rad fan will be used from Mercedes W140 and placed before the sandwich. Currently the job is almost done, hope I'll be able to take some pics this week.
Fuel rail will be custom manufactured. Injectors I already have are ACCEL hi-impedance 48 lbs. A bit high-rated for my application but I use to think that they are good for further turbo upgrades.
Engine is almost stock, near a 10000 kilometers after a full rebuild. The only tuning there is MLS head gasket.
The brakes are laying on the shelf, they are from '86 951. I plan to install them just like Raceboy described in this thread.
I was thinking about a custom-made rally suspension, but finally decided to go with Koni Sport inserts/rears and somewhat 200-220 lbs front springs with matched t-bars. Also there will be PU bushings in the front wishbones.
I'll post some pictures this weekend. Since I have no place and tooling, all the works in engine bay are done by our local porsche-guru.
To be continued.
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Wed Jul 22, 2009 6:06 am    Post subject: Reply with quote
Got some pictures from the workshop in my email.
Radiator sandwich cooling fan:
IC and radiator frame:
IC and fan from the valance side:
60-2 toothed ring mounted at flywheel:
here will be the VR sensor:
and it will bolt to this plate:
Here it is:
WBR, Shurick
'86 924S -- R.I.P.
Rich H
PostPosted: Wed Jul 22, 2009 6:13 am    Post subject: Reply with quote
Looking good!
PostPosted: Wed Jul 22, 2009 7:31 am    Post subject: Reply with quote
Awesome! I LOVE pictures Can't wait to see more!
Shurick
PostPosted: Wed Jul 22, 2009 7:42 am    Post subject: Reply with quote
Can't wait to see it running...=) I'll keep you updated, don't worry!
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Thu Aug 04, 2011 4:40 am    Post subject: Reply with quote
After a long break I returned to my 931. Made some oil lines and fitted the oil cooler into it's place.
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Wed Aug 29, 2012 5:06 am    Post subject: Reply with quote
After a long time I have a proof of concept - the car is in running condition for a full season with some minor issues (blown coolant pipes etc.), performed 219 hp at the wheels on the dino @ .75 bar of boost.
Pics and videos are coming soon.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Wed Aug 29, 2012 6:07 am    Post subject: Reply with quote
Bring it!
Ruby-sh 924
PostPosted: Thu Aug 30, 2012 9:53 am    Post subject: Reply with quote
Yea son!
joejax
PostPosted: Thu Aug 30, 2012 9:59 am    Post subject: Reply with quote
Git R' Done!
I got nothin'
Uhhh...you got any pics?
Shurick
PostPosted: Thu Nov 15, 2012 10:08 pm    Post subject: Reply with quote
Some history highlights of my project. Sorry for crappy photos.
2012-01-17: 931 went to our rally race team workshop. There it will be assembled.
2012-03-23: EFI sensors and wiring fully sorted. Have messed a lot with lancer evo intercooler but finally decided to record losses and bought a new one (cheap chinese with core size 450X300X72). Intercooler ports relocated, intake plumbing sorted.
2012-04-01: Got it running!
http://www.youtube.com/watch?v=O_pRNZy3wRA
2012-05-09: Roughly tuned.
http://youtu.be/CdiOcDPUWmw
2012-09-29: Season closed...(((
Plans on winter: sort all bodywork issues, install fender flares to adopt fuchs wheels, respray car in Riviera Blue. Maybe replace K26 with GT28RS and tune to 17-18 psi, but it depends on budget.
WBR, Shurick
'86 924S -- R.I.P.
924-76
PostPosted: Fri Nov 16, 2012 8:03 am    Post subject: Reply with quote
Interesting intake manifold
Could you tell us more about it and post more pics
Thanks
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Shurick
PostPosted: Fri Nov 16, 2012 7:37 pm    Post subject: Reply with quote
Thanks
Here's a thread about it: http://www.924board.org/viewtopic.php?p=250147
Finally don't sure if it performs better than stock, but it eases packaging in one way and complicates in another. It took too much time and effort to build and adopt this plenum, it's support, throttle linkage and so on.
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Mon Mar 04, 2013 5:21 pm    Post subject: Reply with quote
So, resurrection started:
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Mon Mar 04, 2013 6:30 pm    Post subject: Reply with quote
widebody? you too ?
Ruby-sh 924
Page 1 of 6
