modify 931 exhaust
Goto page Previous  1, 2
PostPosted: Sat Jan 28, 2017 6:22 am    Post subject: Reply with quote
My WG is not bolted to anything else but the pipe holding it.
It has been like this since 2007.
Recipe for a broken J-pipe.
I don't blame you morghen, those are 2 of the absolute hardest bolts to get period..
I've not had any issues with any of the ones that I've put back together using the factory mount points at the torque tube, one of those builds is going on 10 years, and the other 6.
What is your method to get these bolts? Or this mount in general..
The only way I have been able to do it is mount the WG to the pipes first and then the WG plate thing to the bracket left on the TT, 2 bolts in slider holes iirc..
Take about 10 minutes a piece with a stubby gearwrench, and a 2nd wrench, with the tippy tips of my fingers..
Do you know of a better order of operandi, or method of assembly?
Page 2 of 2
