82 924 with Audi 4.2l
Golten951
PostPosted: Fri Jan 04, 2019 4:33 am    Post subject: Reply with quote
cool ! get it started already
Haha I wish I could!! Going to be great!
ras924
PostPosted: Sun Feb 03, 2019 4:21 am    Post subject: Reply with quote
...nice to see you are still moving forward!!!
1980 924 N/A - White
1978 924 N/A - Yellow Rally Car
Golten951
PostPosted: Tue Feb 26, 2019 4:06 pm    Post subject: Reply with quote
Thanks Ras924, doing my best with alotted time and all.
I will be taking a week off to get more progress next month!
Golten951
PostPosted: Fri Mar 01, 2019 9:30 am    Post subject: My youtube link Reply with quote
https://youtu.be/3DZTeh1uXtQ. Here is my Youtube link
Golten951
PostPosted: Thu Aug 29, 2019 9:55 am    Post subject: Update Reply with quote
I am breaking away from all stock gauges for my Audi 4.2L Swap in my 924. Main reason is I would like to try and make this car Legal in CA to actually drive around. So I am going to use an A8 cluster and, match everything up with the harness. also will have the OBD2 port set up, so I can read any codes and trouble shoot as much as possible. At first I wanted to stay stock gauges, but in the end, this will be very accurate.
Golten951
PostPosted: Thu Aug 29, 2019 2:51 pm    Post subject: New clip link, unsure why the other failed. Reply with quote
https://www.youtube.com/watch?v=3DZTeh1uXtQ
Golten951
PostPosted: Wed Sep 04, 2019 2:21 pm    Post subject: Update Reply with quote
Modification of Harness from the 2001 A8 donor car underway, trimming it down to what is needed for my 924 Audi 4.2 Swap. leaves me with a lot of extra wiring for splicing if needed. Also the fuse block will be a nice update from the old ceramic fuses not to mention the wiring from the early 80s.
Golten951
PostPosted: Tue Oct 08, 2019 3:41 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=xsYmkN9mptQ&feature=share
Golten951
PostPosted: Wed Oct 09, 2019 6:49 am    Post subject: Last update till December Reply with quote
Last update on my 4.2 swap 924 until December.
Had a good plan forward for my radiator, Brake and clutch. Plus possible Fusepanel layout.
https://www.youtube.com/watch?v=HnKwLaSBGnM&feature=share
PostPosted: Wed Oct 09, 2019 5:13 pm    Post subject: Reply with quote
cant wait to see this thing done
Ruby-sh 924
Golten951
PostPosted: Thu Oct 10, 2019 2:08 pm    Post subject: Reply with quote
Thanks Morghen, it has been a lot of work! But will be epic!
Golten951
PostPosted: Tue Nov 05, 2019 6:14 pm    Post subject: Update Reply with quote
Bit of a thought update, I have been working through ideas and ways to have functioning AC and Heating in my 924. If I leave the stock set up, I will only be able to run Heat with no AC. So my plan is to adapt a 85.5 HVAC interior unit into the cabin. I managed to get the whole interior unit for free, with wiring so if it done not end up working out, there is no lose at all, just possibly a more costly way of getting AC. reason for this change is I have to mod the firewall to keep the engine at a good location and set back in the engine bay, this mod took away the room for the stock AC unit that normally sits in the passenger foot well. Once I can work on my swap in Dec, I can get a lot more practical information.
Golten951
PostPosted: Thu Nov 07, 2019 12:14 pm    Post subject: Switch and Stalk update Reply with quote
Since I will have the A8 Interior wiring, I will be using the A8 Headlight switch, turn signal and wiper stalks, plus the Ignition switch and key. Will have to do a little custom fab work... but what has not been custom on this whole swap?? lol., will update more as I go.
PostPosted: Thu Nov 07, 2019 6:17 pm    Post subject: Reply with quote
Ruby-sh 924
Golten951
PostPosted: Thu Nov 07, 2019 7:59 pm    Post subject: Reply with quote
haahah, I can not figure how to load them properly after Photobucket went a bit rogueish. I have two other forums to easy post pictures on.
https://rennlist.com/forums/924-924s-and-931-forum/1123100-audi-4-2-in-an-82-924-a-2.html
http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/941956-audi-v8-924-a.html
I will keep trying to get the image stuff sorted. [/img]
Page 2 of 4
