Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Fri Jan 20, 2017 12:04 pm Post subject: |
Fascinating video Fast Eddie, thanks! |
Noahs944
Posted: Fri Jan 20, 2017 1:42 pm Post subject: |
Decided to run with the smaller vents on the front fender. Something feels like early corvette stingray to me. Love it.
Btw-under the hood doesn't look half bad. Will be painted of course.
Posted: Fri Jan 20, 2017 2:11 pm Post subject: |
I louve it _________________ Toofah King Bad
Noahs944
Noahs944
Posted: Sat Jan 28, 2017 1:10 pm Post subject: |
Alright, so SLOMO asked me what I did for lightening the doors, so here goes:
Noahs944
Noahs944
Posted: Wed Feb 01, 2017 3:23 pm Post subject: |
Finally grabbed my best cat and headed out to the garage. It's been a tough couple of weeks but I ain't hurrying for no one... for nothing. I'm doing everything right this time.
Removed the spoiler. don't need it anymore.
Noahs944
Posted: Fri Feb 03, 2017 1:46 pm Post subject: |
In my pursuit of less lift I would like to build a rear diffuser. The back end of this car isn't so easy to do that with.
Check out this video. Have you ever looked under a Lotus? SMOOTH ALUMINUM... 100% These cars COOK, I had a very rapid trip around the Autocross circuit last summer. Soiled myself!
https://www.youtube.com/watch?v=q8hIxMzqW0c |
Noahs944
Posted: Fri Feb 03, 2017 3:04 pm Post subject: |
Painted the backside and applied the LePage construction adhesive before the ss rivets.
Here's a comparison of width and length of the new wing versus stock spoiler.
Noahs944
Noahs944
Posted: Sat Feb 04, 2017 9:18 am Post subject: |
vs:
Noahs944
Posted: Sat Feb 04, 2017 10:21 am Post subject: |
One concept that has been tantalizing my taste buds has been the concept of flipping the header but there isn't enough clearance. Also I need to read up on the function of the blow off valve and recommendations for mounting position of it externally.
Noahs944
Posted: Sun Feb 05, 2017 11:21 pm Post subject: |
Alright so to avoid confusion, my intent wasn't to build a "Hater pipe" through the hood LOL. I was considering making a exhaust manifold that used the oem primary tubes welded to a "log" and routed around the front of the engine. Benefits would be:
-less exhaust near the fuel lines(lessen chance of fire)
-less exhaust congestion to deal with (only a single pipe going rearward - like an n/a).
I wanted to to explore ALL options of air management (routing specifically). But after consideration, the idea is rejected. I have decided to mount the turbo and exhaust pipe very similar to how Spencer's picture shows... based on oem concept, but a bit differently.
Future ambitions will probably include a rad/intercooler extractor vent like in the following pictures, so I need to keep the area "free". Fortunately the afm will be out of the way (because standalone/map sensor replaces) & if I re-route the upper rad hose I should be golden.
Noahs944
Posted: Mon Feb 06, 2017 5:47 am Post subject: |
First step for me today was building a turbo mount using the supplied manifold flange. This is what drives the turbo with exhaust gas. Unfortunately the flange is not threaded, which means bulkier mounting because external nuts.
I used 2 1/2" exhaust pipe with enlarged ends. I had to "shrink" the ends to fit the flange as closely as possible with vise grips after turning the round tube square with a hammer & a bench vise.
Posted: Mon Feb 06, 2017 6:57 am Post subject: |
Pretty cool you're doing this.
Cant wait to see this thing running...I wonder how you will find the turbo cars. _________________ https://www.the924.com |
