Robert Hooper
Joined: 15 Mar 2004 Posts: 70 Location: Christchurch NZ
Posted: Fri Oct 06, 2017 5:21 am Post subject: Porsche 924, Race weekend in car footage |
Hi All,
Thought I would post some footage of my car at Ruapuna a few weeks back, got a new fastest lap!
Insert URL: https://youtu.be/S-KeSFRL2U4 _________________ 1982 924 Race Car
1981 931 Road Car |
Kenodog
Posted: Fri Oct 06, 2017 6:41 am Post subject: |
That is a pretty quick little 924. What powerplant is in it ?
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Robert Hooper
Posted: Fri Oct 06, 2017 7:56 am Post subject: |
Car is running the 3L 968 motor, 60mm ITB's, custom cams, running just over 300hp,
The car is very light, its has no glass all perspex and lots of fiberglass, it is a 924 with the engine mounts cut from a 968 to accommodate the engine and gearbox changes.
The limiting factor is i am running a 951 gearbox at the moment, so the gears are too long, 177 in 3rd etc... I am rebuilding a 6 speed at the moment.
The other thing is that i dont run slicks, just toyo R888's and i have no grip, so slipping around a bit,
Cheers Rob
[img][img]
[img]
[/img] _________________ 1982 924 Race Car
1981 931 Road Car |
KDJones2000
Posted: Fri Oct 06, 2017 2:27 pm Post subject: |
I think I'm in love with your engine
Why is your shifter so loose? I would think you are at risk for mis-shifts with as much play side to side that you have in that video. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
Posted: Fri Oct 06, 2017 10:02 pm Post subject: |
Very nice!!! _________________ Vaughan Scott
Posted: Fri Oct 06, 2017 11:07 pm Post subject: |
Add some chassis stiffening before going on slicks..actually you could do it now too and it would be a good idea _________________ https://www.the924.com |
Robert Hooper
Posted: Tue Oct 10, 2017 11:31 am Post subject: |
"Why is your shifter so loose? I would think you are at risk for mis-shifts with as much play side to side that you have in that video."
I had some real issues with the shifter breaking when i first ran the car, the plastic bit that holds the ball joint at the bottom kept heating up, getting loose and coming out, so i replaced it with a rose joint, this makes the gearstick move around a lot, i hadent noticed it while driving but it looks bad in the video,
Will come up with a fix before the next race! _________________ 1982 924 Race Car
1981 931 Road Car |
