Qik Nip
Posted: Tue Nov 29, 2016 5:03 am Post subject: More lowering issues. Need help |
Well when I got serious about lowering the front end to match the 3" rear drop, I discovered that (with the present Paragon lowering springs) I have just about 1.5" of shock travel before bottoming out the Billstein Sports struts. So lowering it 3" isn't possible as configured.
As background, it's a 1979 NA that I built to run Bonneville. At present it peaked at 142 and we're targeting 150+. I'm maxed in the engine departemnt and have very limited aero changes that I can make in my class. So to get it going faster, I have get it a lot closer to the ground.
To address the necessary lowering target it looks as though I'll either need to find a strut with a shorter body, or (better choice) a means by which to raise the upper strut mount. Does anyone here know of that strut or a upper mount kit that accomplishes that goal?
Rick _________________ '79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11 |
Posted: Tue Nov 29, 2016 5:45 am Post subject: |
Isn't the GAZ struts really short? Ive heard so at least. Maybe they could give you some measurements? _________________ 1980 924 Turbo
Posted: Tue Nov 29, 2016 8:47 am Post subject: |
What top mount you using? Some flat top mountings waste an inch or two suspension travel. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Qik Nip
Posted: Sat Dec 03, 2016 12:45 am Post subject: |
Carrera RSR wrote: | What top mount you using? Some flat top mountings waste an inch or two suspension travel. |
I'm using the stock top mounts and after talking to Koni, they advised that I could safely trim 2" off the (4") bump stops without risking bottoming out the shocks. With that adjustment made, I now have the front end pretty much at the target ride height and actually have a decent amount of compression travel. Fortunately the camber adjustment excentrics were sufficient to get me to zero degrees camber! While that wouldn't do for road course racing, for LSR use, it's just what I need.
BTW, I did find that Ground Control makes an adjustable camber plate that would have given me some additional space had it been necessary. Hopefullly I won't need to spend that $435, but if I find that the too much caster is lost due to that max camber adjustment, I can use that device to get it back.
