Bryan S
Posted: Sun Nov 27, 2016 12:36 pm Post subject: 1982 924 Turbo Timing Belt/Water pump replacement |
I replaced the timing belt and water pump on a 1988 944 a few years back and followed a very detailed Youtube video that provided step-by-step instructions. Does anyone know if this process is the same for a 1982 924 Turbo? If not, are there any good videos or instructions for the timing belt replacement? _________________ Bryan |
Joined: 28 Feb 2008 Posts: 1137 Location: Washington DC area
Posted: Mon Nov 28, 2016 5:40 am Post subject: |
They are entirely different. The '82 version is dirt simple. Get a Haynes manual. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Edwardsgw
Posted: Thu Jun 29, 2017 2:28 pm Post subject: |
I found replacing the timing belt to be quite easy. I found getting the timing belt cover off so I could replace the belt to be quite challenging (i.e. I would rather do a 944). This forum was quite helpful. One key to allowing access to get the cover off was to unbolt the fuel distributor/metering unit assembly from its mount and disconnect the boot going to the turbo, leaving the lines all connected. This allows it to be moved far enough out of the way to just barely get the timing belt cover off. _________________ 1981 931
1987 944S
1987 300TD Turbo
1987 944 track car
1988 944 Turbo S (silver rose)
1992 500E
1993 400E
1994 E320 Cabriolet
1999 996
1999 SL600
1976 Ford F350 Crew Cab |
