jvandyke
Joined: 30 Mar 2016 Posts: 212 Location: Hudsonville, MI
Posted: Tue Sep 20, 2016 12:52 pm Post subject: exhaust sealing ring removal? |
Any tip for getting the old exhaust sealing ring out of the joint between cat and the muffler? I thought I'd better replace it. Just pry and pound or is there a cute trick to it? _________________ 87 924S project, '83 944 engine,
my son's first car. |
Posted: Tue Sep 20, 2016 12:58 pm Post subject: |
No trick, just needs persuasion. _________________ White 87 924S "Ghost"
Posted: Wed Sep 21, 2016 1:49 am Post subject: |
Hit it with a little PB Blaster, and then with a sharp punch and hammer. The punch will deform the ring and often make it pop out. If not, it will at least bend it enough to get a prying tool under it. _________________ Toofah King Bad
jvandyke
Posted: Wed Sep 21, 2016 12:32 pm Post subject: |
This is essentially what I did, had PB Blaster'd it last night, tapped it with a hammer and drift it popped out. Was a little crumbled, left a ridge behind, cleaned it up.
All back together, off the check list.
Getting closer. _________________ 87 924S project, '83 944 engine,
