Johann
Posted: Tue Sep 13, 2016 10:25 pm Post subject: Where can I buy AOS vacuum lines? |
As you are aware I am in the process of restoring a 1983 ROW 931. I have now replaced most of the vacuum lines, but am unable to find a source for the AOS lines.
I need the following pipes:
931.107.169.00
931.107.171.00
931.107.394.02
Can anyone please point me to a source where I can buy these? |
Johann
Posted: Fri Sep 16, 2016 5:33 pm Post subject: |
Has no one replaced their AOS lines recently? |
Joined: 08 Jan 2010 Posts: 2101 Location: Somerset, UK
Posted: Fri Sep 16, 2016 10:02 pm Post subject: |
Use generic rubber or silicone for nla parts
PS I tried to search those parts numbers for a quick reference. Real hard to locate easily. So no one is going to answer if its too hard to understand the question or part you need. Try posting an image of PET page with the parts highlighted or numbered. Easier for us to help _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Johann
Posted: Fri Sep 16, 2016 10:13 pm Post subject: |
Thanks for the advice. I am trying to keep my 931 100% stock so original Porsche spec pipes would make my very happy. My last resort would be generic hoses. I am looking for 27, 35 and 36 in the picture below.
Joined: 01 Oct 2004 Posts: 15510 Location: Woodstock IL
Posted: Fri Sep 16, 2016 10:22 pm Post subject: |
All NLA. You can try contacting your local Porsche dealer to see if there are any languishing on a back shelf of a dealer somewhere in Europe, but that is about your only chance of getting OEM parts. _________________ 75 Fiat X1/9 | 80 US 931 '941' | 78 Poli-Form |
Johann
Posted: Sat Sep 17, 2016 12:18 am Post subject: |
Yeah, I still cannot get used to the fact that so many parts are NLA. On my 964 and even my previous 356 this is so much easier, 98% of all parts are still readily available.
Luckily with enough patience and help from forums such as this one I am managing to locate all the parts I need.
My latest find is the rubber pipe between the AFM and Turbo. My car had a silicone tube that has been sucked flat causing the car to feel suffocated at high revs.
Bit by bit I am bringing this car back from the dead  |
Posted: Sat Sep 17, 2016 1:01 am Post subject: |
Issue is, Porsche can charge a lot more money when recommissioning 911 or 356 part v's 924. Plus the 924 market place has probably been shrinking at OPC for many years. That said they are adding new 924 parts back into the line every quarter. Just because it was NLA does not mean it remains NLA. The rubber hoses into and out of the waterpump are now available again.
The woven pipe can be bought from motor factors or VW Heritage
The rubber pipes into the Purolator are not OEM deal breakers for generic rubber hoses? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Zuff911
Posted: Sat Feb 18, 2017 7:18 am Post subject: |
Johann,
I just replaced #27 on my '80 931, on my car this is wire re-enforced rubber with a woven cloth sheath as is #35 and #36. I was able to locate what I think is the factory hose and had to buy 2 meters of it. If your '83 is similar let me know because even after replacing my #35 and #36 I'll have lots left over.
-Brad _________________ 1980 931
1976 911S
1973 911T |
Posted: Sat Feb 18, 2017 5:28 pm Post subject: |
Erie, CO! Nice! Native Coloradoan and CU alum here. . . _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
Johann
Posted: Sat Feb 18, 2017 10:09 pm Post subject: |
Thank Brad, I sent you a PM. |
