'83 931 idles like a dog when cold - It's fixed!
Goto page Previous  1, 2, 3
Johann
PostPosted: Thu Aug 31, 2017 3:16 am    Post subject: Reply with quote
Not yet, but it is in the planning I am having a custom primary silencer delete pipe made up with a socket for an oxygen sensor.
PostPosted: Fri Sep 01, 2017 4:44 am    Post subject: Reply with quote
Controlpressure cold is 2.0--2.8 (depending on S1/S2)
So I think you injectors are fine
937 DITC
Johann
PostPosted: Sun Sep 03, 2017 7:39 pm    Post subject: Reply with quote
Thanks for the info Dutch924-racer
She is alive
http://www.youtube.com/embed/_JAr97Z_2ig
Johann
PostPosted: Wed Sep 13, 2017 7:23 pm    Post subject: Reply with quote
And now, after fixing many niggles, she idles like a champ. Hot and Cold
To get here I did the following:
- New Coil
- Fixed the engine wiring harness going to AAV and WUR
- Made the idle mixture a lot richer
- Cleaned the connection to the Idle stabilizer
- Ditched my CO meter and adjusted the A/F Ratio with my ears and nose.
http://www.youtube.com/watch?v=ua5snsA5Y3Y
bear924
PostPosted: Sun Oct 08, 2017 11:11 pm    Post subject: Reply with quote
I'm currently running my 924T rick due to a cold start issue as well. What I've discovered is that the oil canister between the turbo and block is causing a vacuum leak when cold.
I'm also getting really poor vacuum reading (ie.. not enough vacuum) which suggests a largish vacuum leak. =Your symptoms sound similar to mine, so I thought I'd mention my findings.
Page 3 of 3
