Rennbay fuel lines
hdrider19
PostPosted: Wed Aug 10, 2016 1:27 pm    Post subject: Rennbay fuel lines Reply with quote
I just got around to ordering mine today. They have 3 different kits online. I wasn't sure which kit I needed so I called them. I spoke to Travis and he was very helpful. He told me that none of the kits were right for the 924S. 85.5 and later is close but to short. Travis is making a set in the correct length for me and said he does several of these a month. I'm glad that I called first instead of just ordering the 85.5 and later kit online. You can't order these online as of now but he said they do enough of them that they will soon list these for the 924S. If you are going to replace your fuel lines CALL them. Much thanks again Travis at Rennbay!
87 924S
PostPosted: Fri Aug 12, 2016 3:26 am    Post subject: Reply with quote
Would that apply to the 1983 944 as well? They have the same fuel line setup.
edredas
PostPosted: Fri Aug 12, 2016 5:04 am    Post subject: Reply with quote
The 924S has the same fuel line routing as the early cars, but uses the late rail, requiring very long hoses. The early rail has both the damper and FPR up near the firewall, so both hoses are very short.
I hope that helps!
'87 924S -Red, 300hp 951 swap
'87 924S -Red, New Project
'87 924S -White, Automatic
'93 Mx6 -White, Megan Racing suspension
hdrider19
PostPosted: Fri Aug 12, 2016 11:15 am    Post subject: Reply with quote
. They have 3 different listings for the 944 cars on their website that you can order. Only the 924S is not listed and you have to call and ask for it. $115.00
87 924S
hdrider19
PostPosted: Tue Aug 16, 2016 1:54 pm    Post subject: Reply with quote
I got my fuel line set in on Saturday. They are plenty long for the 924S. I will need to cut my lines down by the bottom of the firewall to get them to not be to long but the look nice.
87 924S
hdrider19
PostPosted: Thu Aug 25, 2016 10:54 am    Post subject: Reply with quote
HRider, call Rennbay for a fuel line repair kit. Much easier to install with the engine out.
. Thanks for the tip. I wouldn't want to do that with the engine in place. Install was pretty simple. I put a few drops of oil on the collar and threads before tightening. $115.00 well spent. Thanks again. Paul
87 924S
