Why does the 931 have a different Auxiliary air valve?
Johann
PostPosted: Wed Aug 10, 2016 7:55 am    Post subject: Why does the 931 have a different Auxiliary air valve? Reply with quote
The 931 has this auxiliary air regulator:
Bosch part number: 0280140220
Porsche Part number: 931 606 102 00
The Normally aspirated 924 has this auxiliary air regulator:
Bosch part number: 0280140169
Porsche part number: 047 133 453 A
Can anyone tell me what the difference between these valves are since the NA version is way cheaper than the 931 version. Are they interchangeable?
PostPosted: Wed Aug 10, 2016 10:53 am    Post subject: Reply with quote
Is the turbo unit stronger in some way because it's exposed to boost pressure?
PostPosted: Wed Aug 10, 2016 11:11 am    Post subject: Reply with quote
The turbo unit is much larger, has larger orifices, and is not adjustable in the manner that the NA is. As for internals, I don't know what the difference might be.
PostPosted: Wed Aug 10, 2016 12:19 pm    Post subject: Reply with quote
You also might start cross referencing other euro cars. That type of aav was installed on literally millions of cars.
Johann
PostPosted: Wed Aug 10, 2016 4:00 pm    Post subject: Reply with quote
Knowing Porsche there would have been a good reason for it. As far as I know the 931 and 930 share the same valve, so Rasta Monsta, I think you might be correct in that it is very likely that they are beefier to deal with the added pressure in the inlet circuit.
Johann
PostPosted: Wed Aug 10, 2016 7:14 pm    Post subject: Reply with quote
Still scouring the web for answers, but I came across this photo. The refulators seem to be the same size.
