Wobblydriver
Posted: Mon Aug 08, 2016 6:32 pm Post subject: Seized shoes |
Suggestions please. This problem is on an 1984 model. Here are the facts so far. BOTH rear drums are seized solid. It has been parked unused for 10 years, (yes ten). Hand brake OFF, IN gear. It is now up on axle stands. The drums won't turn AT ALL! I've sprayed it regularly with penetrating oil. I've tried to slacken the adjusters, they're seized too. I've had the castle nuts off, the drums are that tight they came off easily. The drum puller just pushed the drive shafts out. I've tapped them with a hammer but I'm cautious of hitting them too hard. What else can I do? _________________ I Know the Voices aren't real, but boy! They come up with some good ideas! |
MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Mon Aug 08, 2016 8:50 pm Post subject: |
Wobbly;
I wouldn't be too concerned about using the Rural technology on those rear drums, they can take quite a hit. I would heat them a little, not too much though because of the brake fluid and lines that are around it. Then take the hammer to them.
I know that my drums were a tight fit when I first removed them to rebuild the rear brakes on my car. They will come off.
Regards; _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Posted: Mon Aug 08, 2016 9:44 pm Post subject: |
Take a bigger hammer, you should change the drums anyway, so damage shouldn't matter  _________________ 1980 924 Turbo
Posted: Tue Aug 09, 2016 1:30 am Post subject: |
From what I've read I believe backing off the adjusters is the key to getting the drums off.. I'd therefore concentrate on them first.. _________________ 80 Turbo - Slightly Modified |
dubrict
Joined: 22 Apr 2011 Posts: 150 Location: Horseheads NY
Posted: Tue Aug 09, 2016 2:42 pm Post subject: |
If it was me, I wouldn't even have the patience to post here about it... I would have grabbed a REALLY big hammer and started destroying long ago.
If the car's been sitting 10 years, it safe to assume you need to replace anything a hammer can break back there.. drums, shoes, bearings, and maybe even brake lines if you're clumsy enough, are all stupidly cheap on this car anyway _________________ 1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota |
Posted: Tue Aug 09, 2016 10:56 pm Post subject: |
| Fasteddie313 wrote: | | From what I've read I believe backing off the adjusters is the key to getting the drums off.. I'd therefore concentrate on them first.. |
+1....I awake to ground hog day. This just happened a few weeks ago on this board _________________ 1980 931 since 1989
POORscheMAN
Posted: Wed Aug 10, 2016 1:04 am Post subject: |
Just put the wheels back on and drag the whole car with a truck until they pop free.
I've always had good luck with that method. _________________ 1978 924
Audi 5K Throttle Body - 10:1 comp
Stage 1 Cam -MSD coil- Crane XR700 ignition - Headers
260# springs -26mm rear TBars-
poly bushings -Weltmeister sway bars
1980 924 N/A -- stock
1982 931
1988 944
1994 968 M030 |
