why is the engine mount different on a 931
Goto page Previous  1, 2
PostPosted: Mon Aug 01, 2016 6:26 am    Post subject: Reply with quote
Fasteddie313 wrote:
you sure its not a secondary lift point for balancing the motor or the way the factories jig grabs it for assembly/installation???
Very interesting thought. I like this idea, especially considering that the 931 would have significantly more weight on the opposite side of the motor due to the turbocharger assembly.
I've never seen anything bolted to this location, and from the detailed pix, I can't see how a stamped piece of metal spot welded to the top of the mount adds any rigidity. And even if it did, why would more rigidity be required there. I wouldn't think the 931 motor would produce sufficient torque to bend the OEM bracket.
PostPosted: Mon Aug 01, 2016 7:33 am    Post subject: Reply with quote
Also interesting since the Turbo has its weight distributed differently but I wonder if something like that would be at the other side since its heavier there
Funny how I saw one pic and thought at first it was to hold a hose
This I know for sure...its there for a reason, some reason
Dan do you have any pics of the factory installing a motor on the production line? Maybe that answers this latest idea
PostPosted: Mon Aug 01, 2016 8:32 am    Post subject: Reply with quote
remember too the other mount on the other side is a beast. Not sure what was in their heads but by the time the 44 came around everything was light aluminum
PostPosted: Mon Aug 01, 2016 11:42 pm    Post subject: Reply with quote
you guys are right. It likely just a lift point.
PostPosted: Tue Aug 02, 2016 1:41 am    Post subject: Reply with quote
I had a look last night at the 937 as well as Woody and Dusty, all of which are essentially unmolested in the engine bay. None of them have anything attached to that bolt hole, so I don't think it is for any "operational" use. I think the best conclusion so far is as a lift or support point to facilitate installation on the assembly line. And sorry, I don't have any pix of that!
PostPosted: Tue Aug 02, 2016 5:18 am    Post subject: Reply with quote
I just thought if anyone did, it would be you. Thanks for checking
PostPosted: Tue Aug 02, 2016 5:40 am    Post subject: Reply with quote
I sent a message to the boys at Flussig. They have some pretty amazing photos, maybe they have something?!
PostPosted: Tue Aug 02, 2016 6:17 am    Post subject: Reply with quote
never tought my question would lead to a two page discussion, love it!
I will wait for the final answer before I get my engine in the 931
PostPosted: Tue Aug 02, 2016 7:58 am    Post subject: Reply with quote
Hmm, gettin' nosy with it eh?
PostPosted: Tue Aug 02, 2016 8:34 am    Post subject: Reply with quote
That would be cool if they had some photo's. I did wander off to look at an 80 and then an 82 (molested versions) but each had nothing there.
...and wow does that color pop!
PostPosted: Tue Aug 02, 2016 11:16 pm    Post subject: Reply with quote
From our friends at Flussig, a clue?
PostPosted: Wed Aug 03, 2016 1:05 am    Post subject: Reply with quote
Do we think this is a jig? Can't really see...
PostPosted: Wed Aug 03, 2016 1:14 am    Post subject: Reply with quote
It appears to be an engine stand, but the photo is so blurry it's hard to make out if it's using that mounting point or not
PostPosted: Wed Aug 03, 2016 1:50 am    Post subject: Reply with quote
Turbo motor is off balance to the side opposite that mount, maybe they used that point to chain the engine down the assembly line.
PostPosted: Wed Aug 03, 2016 7:21 am    Post subject: Reply with quote
Nice job!
To me you guys were right. It has to do with assembly and this was just a jig along the way.
Check out the pile of shifters...the G31 tubes just rolling off the line behind them.... This is a cool pic
Page 2 of 2
