Joined: 23 Jul 2007 Posts: 1077 Location: The Netherlands
Posted: Thu Jul 07, 2016 5:28 am Post subject: Make GT rear fenders wider |
I am convertng my rear trailing arms to late ofsett, I need to make my rear GT replica rear fenders wider (+3cm/ 1.25 inch)
Anybody got an idea whats the best way, where to cut the fiberglass ? _________________ 937 trackday car
Posted: Sun Jul 10, 2016 12:02 am Post subject: |
You could just put a lip on the edge since its not that much. Like a less aggressive version of the rally cars
otherwise I would probably start by "T"-ing the fender from the center. Straight up from the center of the tire and then top the T by going across the fender crease. Then bulge out the two flaps. Then extend the portion from the old crease out to your bulge. This will be a active process since you have to see how it all looks and acts as you go along
Back to the rally lip version. This seems easier. You could cut cardboard and bend a lip along the fender edge a little bit above the edge at an angle. Then you have a pattern for a thin fiberglass strip you would graft in and go from there. This way both sides are fairly equal. Once grafted, cut out the original fender edge/lip from under your newly created lip
A final way is to get a hold of some other flares for another vehicle or small truck and cut off just the lip portion to craft on your GT fenders. This is a bit more expensive though _________________ 1980 931 since 1989
Posted: Sun Jul 10, 2016 4:54 am Post subject: |
3cm is a lot...are you sure you need that much?
Use different wheels and keep the width.
If you drive that car anywhere on the streets and especially in the city you will regret widening quite a lot.
I was recently with my 931 and my GTS wannabe in a different city, it was so difficult to park them, 931 is too low and cant descent into subterain parking lot and GTS wannabe is stupidly wide with big turning circle.
A wide car may look cool but its useless in many cases.
BTW, i'm using 9" wheels front and rear with GTS wings and 951S late setup.
I'm still adding spacers to fill up the arches. Do a trial first as you may have misscalculated that extra 3cm. _________________ https://www.the924.com |
Posted: Sun Dec 18, 2016 2:59 pm Post subject: |
3cm extra width causes parking problems in romania? _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Sun Dec 18, 2016 7:02 pm Post subject: |
joecitizennn wrote: | 3cm extra width causes parking problems in romania? |
Yes.
For real now, my 931 is much easier and nicer to drive around city and park compared to the red GTS bodied 924. _________________ https://www.the924.com |
gegge
Posted: Sun Dec 18, 2016 7:40 pm Post subject: |
My car is low and I got 10" ET23 with R888 245/45-16 inside the rear GT arches. With the 21mm turbo spacer inplace, there is still enough room for an indexfinger. You must have some serious wheels on that car _________________ Carl Fredrik Torkildsen
Posted: Sun Dec 18, 2016 11:42 pm Post subject: |
morghen wrote: | joecitizennn wrote: | 3cm extra width causes parking problems in romania? |
Yes.
For real now, my 931 is much easier and nicer to drive around city and park compared to the red GTS bodied 924. |
I guess roads and parking spaces are much less cramped here in 'merica'. Everything was designed for big detroit boats. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Posted: Wed Dec 21, 2016 10:52 pm Post subject: |
I have 9J rear wheels and there is about 1cm left. The problem is that I run 968 front suspension. So my front wheel extend 3cm more then the rears.
To correct it I bought also the 968 rear trailing arms, but i need some more room for the rear fenders.
as my car is a GT(S) replica I don't want to switch to the late ofset wheel, they all look to modern to my. _________________ 937 trackday car
Posted: Thu Dec 22, 2016 2:13 am Post subject: |
In this latest installment of 'Project Binky' they deal with the extension of the mini 'rallye' arches. I would assume you could do the same with the front and rear GTS arches https://www.youtube.com/watch?v=mB4NXA_vNWs
PS it is worth watching the series from the start if you can stomach the quirky way they present the project!! Great fabrication, if a little Heath Robinson in their approach to engineering issues. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
PieszczoH
Joined: 03 Dec 2009 Posts: 66 Location: Warsaw Poland
Posted: Sat Dec 24, 2016 1:06 am Post subject: |
What about cgts rear Flares ? As the front wings of GTS are wider the rears should be wider to.
Project binky great series. They show how to do it your self in a garage sometimes. |
Posted: Sat Dec 24, 2016 3:53 am Post subject: |
FWIW
v8carreragts wrote: | According to the original Porsche 924 Carrera GTS manual, the GTS has front wings (translation for the German word) that are 10mm wider than the GT. But the rears are the same width. It shows 1745 mm width front and 1735 mm width rear.
This is directly out of the factory GTS manual.
"der GTS wurde an den Vorderkotflugeln um 10 mm verbreitert gegenuber dem CARRERA GT"
Translation:
The GTS was on the front wings to 10 mm wider than the Carrera GT
"Die Gesamtbreite betragt" vorn 1745 mm
hinten 1735 mm
Translation:
The overall width is front 1745 mm
rear 1735 mm
"Die vorderen Kotflugel und die StoBstange ist wie am CARRERA GT ungeschraubt"
Translation:
The front wings and fenders are like the CARRERA GT attached with screws
The Carrera GT is 1735 mm front and rear. |
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
PieszczoH
Posted: Sun Dec 25, 2016 8:43 am Post subject: |
Thanks. Nice info You ve got.
I've always thought that the rear wheel arch in Gts is different shaped becouse it is wider. |
