Gramps Unleashed
Noahs944
PostPosted: Tue Jun 14, 2016 11:09 pm    Post subject: Reply with quote
Regarding the cam grinding, I'm referring to making the base circle smaller. When googling I found this and was impressed by the fellows answer... the very long answer... although not all applies to the Porsche engine. https://answers.yahoo.com/question/index?qid=20071019000014AA0T8uQ
XLR8
PostPosted: Wed Jun 15, 2016 11:46 am    Post subject: Reply with quote
Noahs944 wrote:
Well all I said was I'm thinking about it. There are several other aspects that need research. Such as clutch/bellhousing/input shaft/ign/engine mounts/harness adaption, etc.
Common belief is the n/a CIS can be used for a built 2.0 (150-160 hp). Well that's stock 2.5 territory.
My exploration into the swap will reveal more. If you've already done this research then feel free to post the info. In the end I think I'll just rebuild the stock 2.0. (It's leaking and someone appears to have stripped out all of the allen bolt heads from one end to the other). Nice
Apologies, I did not mean to discourage you AND I misread what you were planning on doing. I thought you were putting CIS into a 944!
I too dream of more power for my NA, but the $ and frustration that my research has uncovered seems to point to persisting with the NA. Just about everything else requires a full drivetrain swap ...
If you did put the 2.5 in the NA shell (+ crossmember + torque tube + tranny) then it's not a huge effort to put EFI onto that engine. Less stuff in the engine bay as well.
My $0.02 (having not done either).
'81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100
Noahs944
PostPosted: Wed Jun 15, 2016 10:49 pm    Post subject: Reply with quote
Absolutely no apology necessary mate. Perhaps I was too subtle.
Update: I have it on good authority that the 79 928 intake manifold is too tall to fit under the hood of the '24/'44.
Power Tryp
PostPosted: Thu Jun 16, 2016 5:27 am    Post subject: Reply with quote
Neat read.
If you plan on doing head modification and cam work, boy have I got a deal for you on a decent head and a cam core to practice on.
Just let me know.
Melanie - 1980 931
Scrappy - 1980 924 shell
Green tartan interior, you don't see that on a Civic.
Noahs944
PostPosted: Wed Jul 20, 2016 1:00 pm    Post subject: Main Bearings? Reply with quote
Ummm, how does a guy find crankshaft main bearings for the 2.0? Seems like no one has them
Power Tryp
PostPosted: Wed Jul 20, 2016 1:16 pm    Post subject: Reply with quote
EBSracing doesn't have any? You may be relegated to ordering from Mittelmotor in Germany.
Melanie - 1980 931
PostPosted: Wed Jul 20, 2016 5:44 pm    Post subject: Re: Main Bearings? Reply with quote
what happend?
red 924 and not red 924
PostPosted: Wed Jul 20, 2016 11:19 pm    Post subject: Reply with quote
I got some piston rings from EBS last week and Troy said he had the main bearings.
Mike
'77 924
cricketdesigns.com
Noahs944
PostPosted: Thu Jul 21, 2016 12:42 am    Post subject: Re: Main Bearings? Reply with quote
what happend?
Nothing. Except Gramps is dripping a lot of oil. I can't tell exactly where it is coming from... so right now, my plan is to: repair the fuel system so he doesn't act up when hot. Once reliable, dis assemble the 2.0 and try to up his power out put by another 20%.
Thanks Mike and PT for the tips.
PostPosted: Thu Jul 21, 2016 1:26 am    Post subject: Reply with quote
Is it smoking or is it leaking out?
Noahs944
PostPosted: Thu Jul 21, 2016 1:16 pm    Post subject: Reply with quote
Very minor smoking, but major oil leakage. As best I can tell, it's front crank seal, oil pan gasket and rear main dripping. All oil pan gasket and front pulley bolts are rounded out. Records show main bearings and rear main were done but... the workmanship is so crappy I don't trust any of it.
It's very possible I mis-diagnosed the head gasket a few months ago, as I didn't find actual damage to the gasket.
GOOD NEWS: called EBS Racing and they have in stock std and oversize main bearings AWESOME.
Bad news is the wife told me I need to cough up $3000 for hail damage repairs... so I am re-assessing everything due to finances.
Honestly I like the 2.0 litre... it's a cute little engine & I think it has potential
PostPosted: Thu Jul 21, 2016 1:57 pm    Post subject: Reply with quote
Main bearings also here:
http://garage.ideola.com/prod-EngineRebuildKits.html#block
I provided the samples and went in with EBS to get that last run of bearings made, FWIW.
Noahs944
PostPosted: Thu Jul 21, 2016 3:14 pm    Post subject: Reply with quote
Thank you for your valuable add, Dan!
Question: if you wanted to up the compression to say 11.5:1 (using stock pistons), is this possible on the na 2.0l by merely shaving the head, or is shaving the block required?
PostPosted: Fri Jul 22, 2016 2:01 am    Post subject: Reply with quote
DO NOT shave the head! The NA head is a heron style head, meaning it is flat, with no combustion chamber in the head itself. You will not gain a single point of compression by shaving the head, you will only affect your ability to properly tension the timing belt.
Have you seen my compression ratio calculator?
http://garage.ideola.com/top-DL-CompressionRatioCalc.html
If you start with US-spec long block from 1980-82, you have 9.0:1 CR pistons to start with. Assuming you don't want to go to the expense of finding Euro-spec pistons, or swapping in something aftermarket or custom, this is your best starting point.
You can gain another 0.4 points of compression by using a Cometic .027" head gasket.
If you take the block down to 230.0mm, you gain 2 whole points of compression, so that would put you at 11.4:1.
So that's how you do it.
If you remove that much material from the block, you should consider an adjustable cam gear to dial in cam timing.
Power Tryp
PostPosted: Fri Jul 22, 2016 2:06 am    Post subject: Reply with quote
Hey, I have exactly that short block sitting around taking up space. How funny is that?
Melanie - 1980 931
Page 2 of 3
