heater hoses
nightrunner68667
PostPosted: Sat May 21, 2016 9:38 am    Post subject: heater hoses Reply with quote
Removed wur for cleaning so in the process of replacing all the heater hoses, and the many elbows, found a hose at Oreilly's (part # 18937), that works for the elbows, got 2 out of this hose plus the piece at the heater control valve ($12.22)
Ok, for the question, where does everyone get the hose that is real large on one end and small on the other? I have seen it for 40.00, is that for real? I will try and put a pic of the one that I am talking about.
Last question, what all has to come off to replace the elbow at the turbo??
O, one last question, where is the best place to get the hose that runs from the control valve to the heater core?
Thanks.
Darrell.
[img][/img][img][/img]
Always wanting to learn.
PostPosted: Sat May 21, 2016 10:25 am    Post subject: Reply with quote
If you check the tech section I think you'll find an article about removing that recirculation valve cover to address a rattle in the turbo.
nightrunner68667
PostPosted: Sat May 21, 2016 10:39 am    Post subject: Heater hoses Reply with quote
Found it, thanks.
