924 Carrera GTS replica tach/boost gauge
Raceboy
PostPosted: Fri May 13, 2016 11:09 pm    Post subject: 924 Carrera GTS replica tach/boost gauge Reply with quote
Made 924 Carrera GTS replica tach/boost gauge out of 924S/944 tach with MPG gauge. Porsche also used same hardware, just different electronics and faceplate. I had the custom backround made and printed onto UV resistant matte surface. Later may do it properly with silkscreen print.
I used 911 speedo needle (it is longer on the opposite side and matches 924S MPG gauge needle better than original needle).
Click for a photo: https://scontent-arn2-1.xx.fbcdn.net/v/t1.0-9/13151995_1034961566582857_957268573368076216_n.jpg?oh=dcef919a7964e882105f17f30cd66cb9&oe=57E6998D
'83 924 2.5 16v Turbo, 470hp
'89 944 S2
'91 944 S2
'78 924
'78 911 SC 2.5 ss Turbo "Martini"
'82 924S/931 "Gulf" racecar, 330 hp, sold
'84 924, turbocharged, sold.
PostPosted: Fri May 13, 2016 11:10 pm    Post subject: Reply with quote
That is *way* cool!
How did you do the boost sensing part?
Raceboy
PostPosted: Fri May 13, 2016 11:12 pm    Post subject: Reply with quote
I left it like it is, VEMS is controlling the needle. But lot is ahead, I want to get it working with original MPG hardware, last resort is to use separate 924 tach circuitry outside of the tach housing (bulky and not so elegant solution).
'89 944 S2
'91 944 S2
'78 924
Raceboy
PostPosted: Fri May 13, 2016 11:22 pm    Post subject: Reply with quote
As a comparison, here's original GTS tach:
https://scontent-arn2-1.xx.fbcdn.net/v/t1.0-9/11188302_831200203625662_8474099734312981792_n.jpg?oh=2e18e5e2f2f3bbe15cb0da572432170b&oe=57DBD947
'89 944 S2
'91 944 S2
'78 924
PostPosted: Fri May 13, 2016 11:39 pm    Post subject: Reply with quote
Brilliant, Peep. I want one!
PostPosted: Sat May 14, 2016 1:03 am    Post subject: Reply with quote
Way cool, i'd love one like that but to work without VEMS
I made a speedo that fits inside the 924 dash and looks like the 924 one but uses the 944 gearbox sensor instead.
Was planning to use that early tacho to try to fit a boost gauge and do a GTS replica tacho but you beat me to it
https://goo.gl/photos/yQFjASpwXLRPv6Vx9
red 924 and not red 924
PostPosted: Sat May 14, 2016 1:01 pm    Post subject: Reply with quote
Glad you got it to work, it's been a year since you received it, I was beginning to wonder...
Raceboy
PostPosted: Sat May 14, 2016 5:31 pm    Post subject: Reply with quote
I focused on it again about a month ago after I had other priorities during winter
Thanks Paul!
'89 944 S2
'91 944 S2
'78 924
WEASEL149
PostPosted: Mon May 16, 2016 7:42 am    Post subject: Reply with quote
Very cool!
1979 UK 932
PostPosted: Mon May 16, 2016 3:59 pm    Post subject: Reply with quote
Great, good work!
937 DITC
Magnus
PostPosted: Sat May 28, 2016 4:49 pm    Post subject: Reply with quote
Very nice!!
Do you know how to modify the 924 tach to work with a Link ecu, beeing a high lewel tach it doesnt work for me...
Thanks
931 -81 20vt Restomod build in progress...
Raceboy
PostPosted: Sun May 29, 2016 5:52 pm    Post subject: Reply with quote
I use regular low level output which just has 1k pullup to 12v, it is already built inside ECU.
You can just use some 1k resistor and connect it between tach wire and 12v, should work.
'89 944 S2
'91 944 S2
'78 924
gegge
PostPosted: Mon May 30, 2016 7:47 pm    Post subject: Reply with quote
Where did you get the tachodial made?
http://www.heiler-tachodesign.de
or
http://neutec-tacho-design.de/
Carl Fredrik Torkildsen
Raceboy
PostPosted: Wed Jun 01, 2016 5:28 pm    Post subject: Reply with quote
My good friend designed and drawed it (he is a designer my profession), I just gave him 924S tach for dimensions and sent GTS tach photo and purchased the font used on these tachs (that cost ~20 euros).
When the vector drawing was finished I contacted another friend of mine who works in advertising company and she printed the dials on matte UV resistant sticker.
I will probably make a new set with a bit smaller numbers and when I am satisfied maybe will print it on the spare 944 tach face in silkscreen print like original.
'89 944 S2
'91 944 S2
'78 924
PostPosted: Sun Jan 29, 2017 8:48 am    Post subject: Reply with quote
Pix missing...raceboy, can you fix the links?
