The noise!
Apex Killer
PostPosted: Wed Sep 04, 2002 10:35 pm    Post subject: Reply with quote
Here is what I have got.
When I bought my 924S it had an aftermarket, MOMO gear knob. At certain RPM there is a slight rattle through the knob. I can put my hand on it and it goes away. So I have swaped out the knob for others and the noise is still there. I removed the boot and the conection between the lever and the shaft seems pretty tight.
I am going to go nuts, does anyone have any suggestions or thoughts?
PostPosted: Thu Sep 05, 2002 8:46 am    Post subject: Reply with quote
use lock tight on the nuts other wise they will come loos also go a size smaller and get a piece of plastic to cover it so it doesn't rattle
PostPosted: Thu Sep 05, 2002 9:17 am    Post subject: Reply with quote
My grandfather was a mechanic/service manager from 1916 until he retired in 1966.
He said without a doubt the best thing that was ever put in a car was a radio. "When you hear a rattle", he used to say, "all it means is that you haven't turned the radio up far enough".
PostPosted: Thu Sep 05, 2002 9:20 am    Post subject: Reply with quote
I like it paul you should sit in my car, you can't hear your self think and you breath with the music
dluney
PostPosted: Fri Sep 06, 2002 1:26 pm    Post subject: Reply with quote
The shifter itself is a high wear item. In new condition, it is a straight shaft. As it wears, it gets tapered on both ends until finally the circlip falls off!. A new shifter from the dealer is about $45 and makes a HUGE difference in the shifter feel.
