BillA
Joined: 27 Dec 2002 Posts: 170 Location: Syracuse, NY
Posted: Sun Mar 20, 2016 11:59 pm Post subject: Expansion Tank |
Does anyone know if a 944 coolant expansion tank will fit in the 931. I have one on hand and doesn't appear that it will fit due to the headlight motor.
Thanks.
Bill _________________ BillA
1981 931 |
Posted: Mon Mar 21, 2016 1:30 am Post subject: |
Many have done this. Did you try searching? _________________ Toofah King Bad
Posted: Mon Mar 21, 2016 6:07 am Post subject: |
Are you sure it's mounted far enough back?
It should be mounted under the quarter panel next to the strut tower.
I've not heard of any issues with the headlight motor, just the ignition amplifier on the box. _________________ Stefan
Joined: 08 Jan 2010 Posts: 2312 Location: Somerset, UK
Posted: Mon Mar 21, 2016 6:32 pm Post subject: |
No issues with headlight or ignition box. Fits like a glove _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Tue Mar 22, 2016 1:31 am Post subject: |
Mounting is a piece of cake. Requires some minor modifications to the hoses going to/from the tank.
In the Club Sport with original flip-up headlights and ignition module (no clearance issues):
In the Club Sport after fixed headlight conversion, also showing the liquid-to-air charge cooler water pump mounted to the headlight motor bracket:
Pix of my install on the 941. In this case, I retained the original expansion tank bracket, bent it a little to clear the 944 tank, and reinstalled the 931 expansion tank as a reservoir for the water-meth injection kit.
 _________________ erstwhile owner of just about every 924 variant ever made |
