No start.......
acpeeps
PostPosted: Sat Jan 02, 2016 12:05 am    Post subject: No start....... Reply with quote
I have a '82 turbo, that does not start.
Turns over, but has no spark. We're thinking it's the crank position sensor......
I know theses are '81,'82 specific. I can't seem to find one anywhere.
I'm new to the forum, and I'll use the search button to start looking for threads on the subject.
Are there any substitute sensors?
I got way to many projects
PostPosted: Sat Jan 02, 2016 12:21 am    Post subject: Reply with quote
There are 2 or 3 possible substitutes but none have been tested yet.
You can still find the sensors from parted cars. Place and ad here, you'll get some offers i'm sure.
jason c
PostPosted: Sat Jan 02, 2016 3:03 pm    Post subject: Re: No start....... Reply with quote
Why, have you tested it?
The 931 is an expensive car to throw parts at it......
PostPosted: Sun Jan 03, 2016 3:50 am    Post subject: Reply with quote
oh, forgot to mention, it could also be the ignition amplifier, the thing on the wheel well. Thats a standard BOSCH part, you can surely get it for a beer at breakers yard.
acpeeps
PostPosted: Sun Jan 03, 2016 6:01 am    Post subject: Reply with quote
We've checked the amplifier, and we opened up the computer under the radio. Everything seems to be fine there
PostPosted: Sun Jan 03, 2016 5:33 pm    Post subject: Reply with quote
The "computer" is always fine, its very strong..rarely fails.
PostPosted: Mon Jan 04, 2016 5:29 am    Post subject: Reply with quote
Did you check the thread at the top of this sub-forum?
http://www.924board.org/viewtopic.php?t=22724
Try bypassing the pressure switch and fuel pump relay and see if that helps.
Commonly the electrical connections are the issue nine times out of ten.
Verify you have spark and fuel and work back from there.
acpeeps
PostPosted: Mon Jan 04, 2016 11:08 am    Post subject: Reply with quote
I'll talk to my guy working on it......
