michaelodonnell123
Posted: Mon Oct 12, 2015 12:04 am Post subject: Fuel lines question |
Hey everybody -
Just wondering if these two fuel lines can be replaced without dropping the gas tank? I filled up my tank today and these lines feel moist and wreak of gasoline. Not fun to drive in a car with those raw gas fumes.
_________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
Posted: Tue Oct 13, 2015 11:37 am Post subject: |
Wow, since you unearthed this part, which is not for the faint of heart, (the white plastic cover can be brittle) you might as well drop the tank. Looking at PET, you have two vents, one by the filler and the other on the other end.
http://www.autoatlanta.com/porsche-parts/924S-86-88/porsche_924_parts.php _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Tue Oct 13, 2015 11:48 am Post subject: |
Answer is no, and if you are committed to the car, Dave is right about dropping the tank and restoring everything in the area. _________________ Toofah King Bad
michaelodonnell123
Posted: Tue Oct 13, 2015 12:19 pm Post subject: |
which part is the white plastic cover. The cover that I removed was a metal cover. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
jason c
Posted: Tue Oct 13, 2015 1:00 pm Post subject: |
michaelodonnell123 wrote: |
which part is the white plastic cover. The cover that I removed was a metal cover. |
The metal cover superceeded the plastic cover for fire resistance.
michaelodonnell123
Posted: Tue Oct 13, 2015 1:06 pm Post subject: |
The tank is coming down tomorrow and yes I will fix/replace anything that needs it while I am there.
This is a job for superman. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
jason c
Posted: Tue Oct 13, 2015 1:24 pm Post subject: |
michaelodonnell123 wrote: | The tank is coming down tomorrow and yes I will fix/replace anything that needs it while I am there.
This is a job for superman. |
Not really. Take the rubber portion of the filler neck off at the tank & it is much easier. If you leave it connected to the tank, you'll fight it because it hangs up on the way down.
You'll have to remove or at least lower the trans to get the tank out. That's the hardest part of the job. |
michaelodonnell123
Posted: Sat Oct 17, 2015 2:06 pm Post subject: |
Just finished up the job. Took down the tranny and while I was there I fixed an exhaust leak too. I replaced the gas lines and buttoned everything back up. No more fuel smell and a much smoother idle and responsivness as well by fixing the exhaust leak. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
