chris79
Posted: Wed Aug 12, 2015 12:30 am Post subject: suspension improvement |
It's possibile to upgrade 924 na suspension using parts of transaxale models 944,968, 928,.. or other cars for better sport performances ? _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
Posted: Wed Aug 12, 2015 1:36 am Post subject: Re: suspension improvement |
| chris79 wrote: | | It's possibile to upgrade 924 na suspension using parts of transaxale models 944,968, 928,.. or other cars for better sport performances ? |
Yep. _________________ Stefan
chris79
Posted: Wed Aug 12, 2015 4:11 am Post subject: |
Then I can install 944 suspensions front and rear on my 924?
But with this suspensions I can lower car ? _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Wed Aug 12, 2015 6:20 am Post subject: |
| chris79 wrote: | Then I can install 944 suspensions front and rear on my 924?
But with this suspensions I can lower car ? |
http://www.924board.org/viewtopic.php?p=218957#218957 _________________ Stefan
chris79
Posted: Wed Aug 12, 2015 6:43 am Post subject: |
yes I read this very interesting article and my options are thwo:
specific koni or bilstein yellow (the best choice but expensive considering value and power of car)
early 944 upgrade, first and easyest solution, but I have to change only shock absorber ? And if I want lower 15mm my car, it's possibile with this configuration ? _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Wed Aug 12, 2015 9:27 am Post subject: |
| chris79 wrote: | yes I read this very interesting article and my options are thwo:
specific koni or bilstein yellow (the best choice but expensive considering value and power of car) |
Koni's provide adjustability so you can soften them for the street and stiffen them for the track. You can get strut inserts for your existing strut housings. No need to use 944 struts unless you're fitting brakes and struts from an 86 944 turbo (951/952)
| chris79 wrote: | | early 944 upgrade, first and easyest solution, but I have to change only shock absorber ? And if I want lower 15mm my car, it's possibile with this configuration ? |
Lowering the front end is separate from the use of the 944 parts for the brake conversion. You'll need to buy lowering springs for the 924/early 944 to lower the car properly.
The rear end is adjusted via the torsion springs and how they are installed, so the 944, 951 or 968 torsion bars can be fitted and ride height set where desired.
The rear sway bar from the 924/944/951/968 can be fitted.
The front sway bar from a 944 will not fit without fabricating mountings and linkages. _________________ Stefan
Posted: Wed Aug 12, 2015 3:42 pm Post subject: |
You can keep the 924 suspension and lower the car. You only need lowering front springs and you have to re-index the rear torsion bars(you have to do the same if you install 944 suspension).
If you install 944 suspension you also need 944 brakes(also change the fluid, new disks and pads) and 5x130 wheels(and tyres) so its more cost and work. _________________ Supercharger and EFI kits
https://www.the924.com |
chris79
Posted: Wed Aug 12, 2015 4:11 pm Post subject: |
No, I don't want change even bracke and wheels, then I have to keep 924 suspension.
I have no other choice, koni and lower spring. _________________ Porsche 924 2.0 na 125hp (1979) euro
Joined: 05 Jun 2006 Posts: 1489 Location: Ontario, Canada
Posted: Thu Aug 13, 2015 2:48 am Post subject: |
| chris79 wrote: | | ...I have no other choice, koni and lower spring. |
And T-bars re-index follow by 4 wheels alignment _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
chris79
chris79
Posted: Fri Sep 11, 2015 6:38 am Post subject: |
Anyone know if stock position of eccentric bolt is set to maximum height ?
If so I can buy 20mm lowered spring and regulate eccentric. Thanks _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Fri Sep 11, 2015 9:43 am Post subject: |
sure, why not...
Maybe adjust the torsion bar whilst you're at it... _________________ 1981 ROW 924 Turbo -
Posted: Fri Sep 11, 2015 2:14 pm Post subject: Re: suspension improvement |
That is a great question. Incredible it has never been discussed on this board until now. _________________ Toofah King Bad
chris79
Posted: Fri Sep 11, 2015 6:05 pm Post subject: |
Ok thanks, but my question is if standard position of eccentric is set to maximum height, if not but for example 5mm lower I can't install 20mm lower spring only changing eccentric bolt. _________________ Porsche 924 2.0 na 125hp (1979) euro
