horn worked pre momo, now no horn?
sciroccosteve
PostPosted: Sun Aug 09, 2015 9:32 am    Post subject: horn worked pre momo, now no horn? Reply with quote
had to use my horn, havent since i put a momo in last year.(didnt test when installed either)
put the stock wheel back on for a minute, horn works. Momo, no horn.
What gives? any ideas fellers?
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
Ozzie
PostPosted: Sun Aug 09, 2015 6:59 pm    Post subject: Reply with quote
no earth on the momo
Its AUTO and its BLACK
Montego Black on black/red
michaelodonnell123
PostPosted: Mon Aug 10, 2015 1:51 pm    Post subject: Re: horn worked pre momo, now no horn? Reply with quote
How can you install a steering wheel and not test the horn??? That makes no sense.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
Ozzie
PostPosted: Tue Aug 11, 2015 8:46 am    Post subject: Reply with quote
The stock wheel has a ring, which is in contact with a connection on the control stalks.
This provides connection for the horn, which when the horn pad is pressed, shorts to earth and energises the horn relay.
PostPosted: Wed Aug 12, 2015 7:25 am    Post subject: Reply with quote
??? My momo has two connection,
Earth to release and
earth to contact
I guess you might be able to get a new button for it?
PostPosted: Wed Aug 12, 2015 9:30 am    Post subject: Reply with quote
My aftermarket Momo buttons have grounded to the wheel and therefore the adapter and column and had a separate connection to the ring on the adapter.
If you have two connections, try connecting the ground off the button to the wheel/adapter and the other connector goes to the horn ring connection at the bottom of the adapter.
sciroccosteve
PostPosted: Thu Aug 13, 2015 8:54 am    Post subject: Re: horn worked pre momo, now no horn? Reply with quote
Im the biggest tool in my garage
2000 V6 Passat
C. Montgomery Burns
