Tiny
Posted: Thu Sep 03, 2015 5:33 am Post subject: Odd Battery light behaviour |
Hello all, and thank you for reading
So this only just started to happen...
Scenario:
I'm driving along and whenever I accelerate pretty hard, the battery light comes on. The harder I stamp the gas pedal, the more brighter & intense the battery light illuminates and will stay on.
As soon as I let off the gas pedal, the light goes out.
Anyone experienced this before?
Hoping it's something like voltage regulator, so I'll test alternator output.
thanks all,
Tiny _________________ *****1981 - 924 - Auto - London, UK****** |
Eliza
Joined: 17 Aug 2015 Posts: 174 Location: Prov. Utrecht, The Netherlands
Posted: Thu Sep 03, 2015 11:48 pm Post subject: |
Hi Tiny,
I did. One or more diode(s) in my alternator was/were shot. I first suspected the voltage regulator also, changed it against a new one, no change.
Eventually I used my multimeter to check the voltage reaching the alt light from the alt, a whopping 17 volts.
A replacement alt did the trick.
HTH
Eliza _________________ 1985 924 NA RoW
1981 931 S2 RoW |
