McMichem
Posted: Sun Jul 12, 2015 12:00 pm Post subject: Identify these wires... |
So now that I have my starter issue figured out *I think*, Its time to mess with some other wiring and get my fuel pump going.
Someone cut the wiring on my fuel pump relay and I'm positive I have it figured out, just need a little direction on which wire goes where and need help figuring out if these other wires I found need to be hooked up.
When I first got the car the pump would start and not shut off as soon as the battery was hooked up, so I guess it was jumped but no idea where. Now it doesn't and I need to get it working so I can get it started.
I do have a haynes and do know where the unmarked wires go.
Posted: Mon Jul 13, 2015 12:43 am Post subject: |
There is a signature function on the board (go to "Profile") that most use to put year and model information. This helps you get more accurate answers. _________________ Toofah King Bad
McMichem
Posted: Mon Jul 13, 2015 3:53 am Post subject: |
Took care of that, thanks  _________________ 1980 931 ~ 67,000 miles |
