MAP kpa after EFI install
Ozzie
PostPosted: Tue Jun 16, 2015 3:58 pm    Post subject: MAP kpa after EFI install Reply with quote
The car is running and I'm now starting the tuning process after a Microsquirt fuel only install.
This is a 125 HP vehicle and the best I can do on the MAP is 47kpa absolute at 13.5 AFR at 950 rpm.
I think this equates to 16" hg.
Am I correct?
Messing around with the VE table and waiting on a rs232/USB adaptor so I can tune on the road. The table generated appears to be ok after changing a few figures.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Tue Jun 16, 2015 8:04 pm    Post subject: Reply with quote
not quite right...
check your ign advance, IIRC the stock setup (86.5mm bore and stock cam 9.3:1comp) should yield somewhere around 17"-20, might be a vaccum leak otherwise...
see here:
http://www.924board.org/viewtopic.php?p=246564&sid=0d8b8ee62399fb939583a020025c4f4c
calculator here:
http://www.endmemo.com/sconvert/kpainhg.php
Ozzie
PostPosted: Tue Jun 16, 2015 8:23 pm    Post subject: Reply with quote
Using your calculator I should get nearly 60kpa to get 17" which is wrong.
60 kpa is worse vacuum than the 47 kpa I get now.
0kpa = 30 inches of mercury not 100 kpa.
ATM = 100 kpa
Doing some research I think I need some ign advance.
PostPosted: Tue Jun 16, 2015 8:49 pm    Post subject: Reply with quote
yeah sorry, calc is naff, did you see RC's post at the bottom... 45kpa equates to 16.63"hg in engine terms, so bees dick away from 17"-20"hg range...
i'd still check advance timing and check for leaks, but it's certainly driveable according to raceboy's comment...
Ozzie
PostPosted: Tue Jun 16, 2015 8:57 pm    Post subject: Reply with quote
Yes- think I need to advance the timing a bit more.
will get the light out tomorrow
Ozzie
PostPosted: Wed Jun 17, 2015 7:31 am    Post subject: Reply with quote
this is probably a better scale using KPA abs where 0 kpa = 100% vacuum
http://www.engineeringtoolbox.com/vacuum-converter-d_460.html
Raceboy
PostPosted: Wed Jun 17, 2015 1:01 pm    Post subject: Reply with quote
40-50 kpa at idle with 924 is quite normal. I have had exactly this on pretty much all 2.0 engines I have installed EFI on. On my Gulf there has been ~70 kPA due to ITB's lol
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Wed Jun 17, 2015 4:56 pm    Post subject: Reply with quote
I have -0.5bar(below atmosferic) with a cold engine and -0.6bar with a warm engine on my red 924 turbo. That sounds about the same what you have.
Ruby-sh 924
Ozzie
PostPosted: Wed Jun 17, 2015 6:25 pm    Post subject: Reply with quote
Adjusted the timing today and is now at 42kpa (-58kpa)
Will take it for a run as I think it is too advanced and might ping a bit.
I set the Map so the gauge read the current atm pressure.
Low setting specs are hard to get for a GM 1 bar MAP.
