Ignition key does not always turn
michaelodonnell123
PostPosted: Tue Apr 28, 2015 4:50 am    Post subject: Ignition key does not always turn Reply with quote
Hey everybody -
Occasionally my ignition key does not always turn. It feels like a pin or something is blocking it from turning the car on. Moving [unlocking] the steering wheel has no effect on this. When this happens, I usually have to take it out and try it again a couple of times by wiggling the key a few times and it then finally it turns like normal and the car goes on. I am afraid that one day I wont be close to home and it won't turn no matter what I do.
Suggestions?
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
PostPosted: Tue Apr 28, 2015 5:11 am    Post subject: Reply with quote
My 924S SE does the same thing! I found that using the key one way, works. There's usually a 50% chance of picking the correct side. But, I've got that down to about a 10% chance! No casinos for me! I don't know why it does it either. I have a spare ignition, but that one doesn't turn the plastic part for some reason all the way to start. Might be what happens 'down the road' eh?
michaelodonnell123
PostPosted: Tue Apr 28, 2015 9:46 am    Post subject: Reply with quote
I tried both sets of keys and they are not worn out they and they both have the same problem, it won't always turn the ignition. Sometimes I have to try it 5 or 6 times before it will go. I am thinking I might need a new cylinder and key set. Thoughts? Suggestions?
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
michaelodonnell123
PostPosted: Tue Apr 28, 2015 11:58 am    Post subject: Reply with quote
Is it easier to try to install a new tumbler or just swap out the entire switch [mechanical and electrical] for a good used one.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
!tom
PostPosted: Tue Apr 28, 2015 3:53 pm    Post subject: Reply with quote
I believe I had this symptom before and the advice was to replace the ignition switch.
I can't find a reference to the discussion though so my memory may be faulty.
78 924 NA
5-lug
unheardofinstruments
PostPosted: Mon May 25, 2015 12:09 pm    Post subject: Reply with quote
any chance cutting a new key from the code could make it work again as the keys get worn
where are the codes anyway?
I know sometimes the drivers door lock barrel has a stamped number in other cars and a locksmith with a coed cutting machine can charge you about thirty bucks
There is more to heaven and earth than is dreamed of in your philosophy...
Lefty
PostPosted: Mon May 25, 2015 1:32 pm    Post subject: Reply with quote
Try squirting some graphite powder down the barrel.
Don't use a wet lubricant as this causes problems
Cheers
Lefty
One less beige car
michaelodonnell123
PostPosted: Mon May 25, 2015 2:11 pm    Post subject: Reply with quote
I wound up changing the entire ignition assembly. Three benefits from doing this: the new key works perfect, no wonky ignition issues in the future and my steering column is rolling on fresh bearings now.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
PostPosted: Mon May 25, 2015 7:56 pm    Post subject: Reply with quote
any chance cutting a new key from the code could make it work again as the keys get worn and it gradually fails
I know sometimes in other cars the drivers door lock barrel has a stamped number on it and a locksmith with a code cutting machine can charge you about thirty bucks for a new key (not a copy)
michaelodonnell123
PostPosted: Tue May 26, 2015 2:56 am    Post subject: Reply with quote
I had three sets of keys and all three were giving me a problem. The issue was inside the tumbler itself and not the key. It was just easier to swap the whole part out and be done with it.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
