WTB - windshield moldings and clips
canyonblaster
PostPosted: Thu Apr 23, 2015 3:24 am    Post subject: WTB - windshield moldings and clips Reply with quote
According to Safelite:
Apparently somewhere along my cars life some dipstick glued the windshield instead of using the proper clips. I especially need the passenger side strip and clips but sourcing all three pieces and all the clips pwould be ideal.
Anyone have any ideas for me?
Thanks!
PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Past P cars, 1985 944, 1987 951, 1990 911 C4, 2002 Boxster S, 2005 996 GT3, 2013 911 C2S
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS
PostPosted: Thu Apr 23, 2015 3:31 am    Post subject: Reply with quote
Put a later flush 944 windshield in and ditch the clips, etc.?
PostPosted: Thu Apr 23, 2015 5:55 am    Post subject: Re: WTB - windshield moldings and clips Reply with quote
Thanks!
??? Windshield is supposed to be glued to the body?
The side trims are held in with about 16 clips. They can still be bought from Porsche. The side trims I'm not sure if still available. The rubber infill to the side trims is NLA.
canyonblaster
PostPosted: Thu Apr 23, 2015 6:40 am    Post subject: Reply with quote
great idea. anyone know if this is possible?
PostPosted: Thu Apr 23, 2015 6:45 am    Post subject: Reply with quote
The clips only hold the trim in place, the windshield is still glued-in.
canyonblaster
PostPosted: Thu Apr 23, 2015 6:55 am    Post subject: Reply with quote
someone glued the trims....
PostPosted: Thu Apr 23, 2015 7:27 am    Post subject: Reply with quote
From what I remember of reading the posts about this, the replacement windshields for the early 944's without the antennae have a spacer built in and all that is needed to install is to remove the clip mounts, glue the window in and replace or modify the wiper arms to clear the window.
canyonblaster
PostPosted: Thu Apr 23, 2015 8:00 am    Post subject: Reply with quote
found a used right side from DC Auto, $70. the clips are still available from dealer, steep! $12/each.
jason c
PostPosted: Thu Apr 23, 2015 11:32 am    Post subject: Reply with quote
There are a few different types of 944 windshields. There are also a few different installation methods & seals. The early 944 windshield is smaller than the flush mount so when brought up to flush mount height, it will be short on the sides. The windshield with the encasement is for flush mounting as it has the groove built in to hold the rubber trim surround. There use to be a larger windshield made (not sure if they still make it) for a flush mount that didn't have the encasement. You have to glue the rubber trim down or find a rubber trim that wraps around the side of the glass. You can find this trim at a glass shop in generic bulk, just cut to length. I used this method on my 951 racecar because I used a lexan window.
MikeDanger
PostPosted: Thu Apr 23, 2015 3:33 pm    Post subject: Reply with quote
you can come take mine for $50!
brian19600
PostPosted: Thu Apr 23, 2015 7:52 pm    Post subject: Reply with quote
http://www.ebay.com/itm/Porsche-924-944-exterior-metal-windshield-trim-/321717108727?hash=item4ae7d57ff7&vxp=mtr
http://www.ebay.com/itm/3-piece-PORSCHE-924-WINDSHIELD-MOLDING-TRIM-PANEL-SEAL-Black-76-77-78-79-Early-/121455323778?hash=item1c474d2a82&vxp=mtr
ECS tuning has the clips listed for around $9. Still too expensive.
I read in another post that someone who has already done it was going to do a how-to on putting a newer (late 944?) windshield in an older car. No more trim or clips. Flush mount. I bet a lot of us like to see that. I have to do windshield change too.
v8carreragts
PostPosted: Tue Apr 28, 2015 3:25 am    Post subject: Reply with quote
The late windshield is an easy job. You need the 87 and newer glass. This glass has a thick rubber spacer attached to the glass that spaces it up. It just gets glued into the same place after you remove the little stubs that hold the trim clips. The rubber part has the attachment groove for the rubber trim. It just gets pushed in after the glue sets up. I have this glass in my car.
The 85.5-86 glass used a metal spacer that slipped onto the pinchweld but it is NLA.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze
canyonblaster
PostPosted: Fri May 01, 2015 10:09 am    Post subject: Reply with quote
V8 - thanks. PM sent
