michaelodonnell123
Posted: Fri May 08, 2015 12:48 pm Post subject: Changed Ignition switch and now strange clicking sound |
Hey everybody-
I had my mechanic change out my ignition switch [the whole piece [mechanical and electrical] not just the tumbler] and now I have a strange consistent sound when I drive over 30 MPH. The sound seems like it is coming from the steering column/dash area right where he changed out the part. It is sort of a clicking sound, almost like the sound of a relay failing. Click ...Click....Click. It goes away when I am at a red light. I tried to recreate the sound by jiggling the steering wheel and taping on the steering column but no luck. It seems internal. I know its not my keys because I only had the one key in the ignition.
Once I hit the gas pedal and go around 30MPH it is there again. I am going to take it back to him tomorrow morning to see what it might be. Thoughts? _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
Last edited by michaelodonnell123 on Sat May 09, 2015 2:34 am; edited 1 time in total |
Posted: Fri May 08, 2015 3:00 pm Post subject: |
Does your horn work? _________________ White 87 924S "Ghost"
Ozzie
Posted: Fri May 08, 2015 10:57 pm Post subject: |
speedo cable? _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
michaelodonnell123
Posted: Fri May 08, 2015 11:00 pm Post subject: |
I brought my car to my mechanic and he thinks it might be the speedo cable as well. It sure is strange how it was working perfectly fine before I had the ignition switch changed and now its not. Cars do weird things for sure.
I will keep you posted. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
michaelodonnell123
Posted: Sat May 09, 2015 2:33 am Post subject: |
Update: It's the speedo cable. It's on order and will be swapped out next week. It seems the more I fix- the more it breaks. Sheeeeesh. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
RobertN
Joined: 19 Apr 2015 Posts: 142 Location: Lisburn Co Antrim
Posted: Sat May 09, 2015 5:45 am Post subject: |
Hey mate well found. I can sympathise with you. The more I look the more I want to fix!!
Good luck. _________________ Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders. |
