jvandyke
Joined: 30 Mar 2016 Posts: 212 Location: Hudsonville, MI
Posted: Wed Dec 07, 2016 2:24 am Post subject: gauge coolant sensor differences |
car: '87 924s
engine; '83 944
temp gauge on dash always suspect, tended to read low, now inop.
When looking at sensors I see a difference between that listed for an '87 and those listed for an '83 2.5 from a 944.
What's the difference?
I'm not sure which part to go after for an accurate gauge reading.
The both "look" like this
_________________ 87 924S project, '83 944 engine,
my son's first car. |
Posted: Wed Dec 07, 2016 2:36 am Post subject: |
Your engine is from an '84 944? Not sure on the differences, but, I'd go with the '87 924S part, to match the gauge. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Dec 07, 2016 2:51 am Post subject: |
More likely a ground problem than the sender. _________________ Toofah King Bad
jvandyke
Posted: Wed Dec 07, 2016 4:48 am Post subject: |
I will go after grounds for the gauges then, first. Is there a good electric diagram floating around, this is all I can find, I have the 944 Haynes but that doesn't do me much good for body stuff.
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm _________________ 87 924S project, '83 944 engine,
Posted: Thu Dec 08, 2016 12:05 am Post subject: |
The main ground is up above, can't reach, spot under the windshield area, driver side. Looks like pop bottle tops upside down~! There are blade connections there, and they get corroded. If you remove the dash, much better access. _________________ '83 944 Track car.
Timmay!
Joined: 22 Jul 2006 Posts: 243 Location: San Diego, CA
Posted: Sun Jan 29, 2017 1:03 am Post subject: |
Yes, 2 different sensors. Early has 1 contact for the gauge needle and the base is small diameter (doesn't penetrate water jacket in block) . Late has 2 contacts, one for the needle, one for the idiot light? , base is bigger and it sticks into the water inside the block. _________________ Current project 1981 931
944 spec # 22 924S
77 924 Martini. Rescued. Sold
88 924S SE. Rescued. Sold
PCA since 1985 |
edredas
Joined: 09 Dec 2004 Posts: 861 Location: Charlotte, NC
Posted: Sun Jan 29, 2017 6:21 am Post subject: |
Early 944 sensor
924S Sensor with single blade
Late 944 sensor with two blades. One for temp other for idiot light
I hope that helps! _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
jvandyke
Posted: Tue Feb 14, 2017 5:49 am Post subject: |
Thanks for that!!
Pretty sure we've got the first one pictured: the "button" single contact style.
Probably should have the 924s style to match the gauge, that would be the first thing to do.
BTW the gauge is "working" comes off stone cold and get's to about 1/4 and stays so likely it's just the wrong sensor/gauge combo.
Looks like the middle one is rare, Pelican doesn't show it, cheapest I've found is $80, ouch.
Wonder if one made for the VDO (non oem, right?) is the same resistance?
http://www.autoatlanta.com/results.php?partnumber2=Porsche%20Boxster%20Water%20Temp&narrowcar=924%201986-88&narrowsection=Electrical
Wonder if one of you guys has a used one? _________________ 87 924S project, '83 944 engine,
Posted: Tue Feb 14, 2017 1:05 pm Post subject: |
I'll look in the morning, don't buy anything from AA. _________________ White 87 924S "Ghost"
jvandyke
Posted: Tue Feb 14, 2017 11:25 pm Post subject: |
I hear you about AA. Not happening. Been there. _________________ 87 924S project, '83 944 engine,
Posted: Wed Feb 15, 2017 4:05 am Post subject: |
I have one. Email sent.
[img][/img] _________________ White 87 924S "Ghost"
jvandyke
Posted: Sat Feb 18, 2017 8:57 am Post subject: |
I assumed they were interchangeable, nope. early 944 "button" style smaller, can't put the 924s sensor (nor presummably the later 944 double spade) into the early 944 block. will have to either re-thread the block or get a different gauge. I'm trying to figure out how the early 944 and '87 924s temp gauge compare, maybe (since I think each gauge is individually mounted?) I can swap out just the temp gauge? _________________ 87 924S project, '83 944 engine,
Posted: Sat Feb 18, 2017 1:17 pm Post subject: |
What color are your gauges? I may have one. _________________ White 87 924S "Ghost"
Posted: Sat Feb 18, 2017 1:22 pm Post subject: |
Email sent. _________________ White 87 924S "Ghost"
edredas
Posted: Sat Feb 18, 2017 7:07 pm Post subject: |
Ah, I thought they would be interchangeable too... I seldom come across a very early block so keeping track of everything is difficult. I have two "early" blocks, or at least what I consider them early since they have the 3-piece oprv and eccentric tensioner, but use the late temp sensor so I wasn't aware the size changed. _________________ '84 944 -White, Brown interior
