Curb Weight and Power
DZGunner
PostPosted: Tue Mar 24, 2015 2:10 pm    Post subject: Curb Weight and Power Reply with quote
What's the lowest you guys have been able to, or have heard of getting the curb weight of 931's down to.
I used a weigh station down the street from my house and got 2470lbs.
I don't know how accurate the scale is but that seems about right with all the stuff I've pulled out. My owner's manual says the stock weight is 2822lbs. So i managed to cut 352lbs of: AC, carpets, heating, rear seats (upper only), Evap system, Radio (with antenna).
As for the power; My understanding is that the 80 and below turbos made 158HP? and then the S2 setup made more, but idk if the S2's made 170 or if that was the euro models.
I'm putting a MBC in my 80 and was wondering what my power figures might look like with a stock, healthy engine at 9-10 PSI.
Thanks guys.
1980 931 S (The project)
1979 924 (Daily driver)
1979 924 (Parts)
1977 924 (Pop's)
1977 924 (Parts)
PostPosted: Wed Mar 25, 2015 1:46 am    Post subject: Reply with quote
I'd reckon the scale is a bit off! Those pulled items don't seem to add up to 352 pounds. In any case, I've had both engines in my CGT clone, and couldn't tell the difference by the seat of my pants. I also have the top mounted intercooler, and a manual boost gauge, set around 10-12psi, and a Euro turbo-charger. Rebuilding the Series II engine this summer, for one last shot at durability for the track car.
PostPosted: Wed Mar 25, 2015 2:31 am    Post subject: Reply with quote
My 924S race car is about 2400 with cage. I suppose the engine might be a bit lighter than the 931.
Not sure I would have deleted the defroster.
Raceboy
PostPosted: Wed Mar 25, 2015 3:08 am    Post subject: Reply with quote
2.5 engine is not lighter than 931 engine even with turbo and CIS stuff combined.
They are pretty much the same, but you can get 931 one a bit lighter when going EFI and dumping CIS.
'83 924 2.5 16v Turbo, 470hp
'89 944 S2
'91 944 S2
'78 924 Carrera GT project
'78 911 SC 2.5 ss Turbo
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Wed Mar 25, 2015 4:08 am    Post subject: Reply with quote
I've scaled my gts wannabe 924 at 1170kg with a decent amount of fuel in it.
Euro model S1 makes 170hp and the S2 euro model makes 177, both no intercooler. Us models might make less power.
red 924 and not red 924
PostPosted: Wed Mar 25, 2015 5:14 am    Post subject: Reply with quote
That's 2579.408 lbs for those that aren't metrically inclined.
PostPosted: Wed Mar 25, 2015 5:24 am    Post subject: Reply with quote
When we corner-weighted the Club Sport, it was dead nuts on 2500# with half a tank of gas. That's with some serious lightening, and a little weight added back in (bolt-in Redline style rollbar and top mount charge cooler setup).
US BHP figures are 150 and 158 respectively according to tech specs booklet. IMO, almost all of the power difference between US and Euro is due to the half-point less of compression and timing. I don't think much is attributable to emissions equipment as is commonly cited.
PostPosted: Wed Mar 25, 2015 7:23 am    Post subject: Reply with quote
Corner weighted at 1140kg (2510lbs) with lots removed but big items added back like a full cage, half tank of fuel, 951 IC, bigger rad = more coolant etc. feels quite lively with circa 220+bhp
DZGunner
PostPosted: Wed Mar 25, 2015 2:13 pm    Post subject: Reply with quote
Whats the timing set at for euro models?
1979 924 (Parts)
1977 924 (Pop's)
1977 924 (Parts)
PostPosted: Wed Mar 25, 2015 4:12 pm    Post subject: Reply with quote
Can't imagine how a cast iron 2.0 block is anywhere near the weight of an all alloy 2.5. Yes, it has two balance shafts, but it doesn't even have main bearing caps and the crank girdle weighs less than the Sunday paper!
Raceboy
PostPosted: Wed Mar 25, 2015 5:11 pm    Post subject: Reply with quote
I have both blocks sitting side by side in the garage, it is not a guess.
2.5liter block is much bigger (=much more material) and 2.5 liter crank weighs much more than 2.0liter crank.
'89 944 S2
'91 944 S2
Cédric
PostPosted: Wed Mar 25, 2015 5:14 pm    Post subject: Reply with quote
http://utzon.se/information/My931.html
895kg = 1973lbs , thats a light car. But it takes som dedication.
´80 924 Turbo
Shurick
PostPosted: Wed Mar 25, 2015 5:35 pm    Post subject: Reply with quote
Porsche 924 tech specs lists dry weight for a 931 engines: 165 kg.
Porsche 944 workshop manual lists dry weight for 8v 944 engines: 166 kg.
I was shocked too.
BTW, euro 924 engine (XK) weights only 136 kg.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Wed Mar 25, 2015 8:57 pm    Post subject: Reply with quote
hmm, here i was thinking i have a light 924 when actually its one of the fattest
PostPosted: Thu Mar 26, 2015 3:05 am    Post subject: Reply with quote
Certainly true. . .the crank is beastly.
