1982 931 - Choices
cahillsm
PostPosted: Sat Dec 27, 2014 5:31 am    Post subject: 1982 931 - Choices Reply with quote
Hello everyone, I'm looking for some sage advice about what to do with my 1982 931. This is a car that was purchased new off the lot by my father and a car we now jointly own. It has had a rough life for sure, but we want to breathe some new life into it and try to enjoy it a bit.
First off, I have been reading thru your forums, and others, and realize that most likely this car will never be worth it to 'restore' for a monetary perspective, and that's not an issue. This car has far more sentimental value than I suppose it will ever have in actual value. With that in mind... it's story:
It was never drive particularly carefully, the front spoiler has significant damage. In the early 90's, it 'ate' a deer. This caused quite a bit of damage to the vents on the panel above the bumper, and to the radiator among other things. Then it sat for almost decade before it was take to a local mechanic to "get it working". After many fuel delivery related issues (pumps and filters mostly) the mechanic let it sit, and then gave up on it. While it sat, it developed cracks in the dash and other interior degradation. After it came back home, we had a nasty wind storm one day that damaged part of the house knocking debris onto the car, nothing major, just more dents and dings. Several years after that, we took it to a Porsche certified mechanic (semi-local) and he agreed to repair the engine. He was almost finished, after a distributor swap and several other new and replaced parts, when the timing belt broke. At this point, he no longer wanted to work on the car and we took it back home (2008-ish). Then it sat again until last year when I decided it was time for me to help. Over the past several months, I've assessed the vehicle condition and started making a (quite long) list of things that need to be done to the car, and things I'd like to do to the car. I'm really not interested in conversions, or large mods and as such, the goal is to make the car drive as much like my father remembers it as I can.
Okay, long back story, but I thought that if I wanted genuine help, I should explain the situation as best I could.
So now for the actual questions. I a 90% sure that the engine has at least one bent valve, is still missing several parts (the radiator overflow being the most crucial), and is overall in fairly poor condition as it needs mostly of the rubber hoses and probably most of the seals replaced. This means a rebuild. I've have trouble locating anyone in my local area that can/will work on a 931 (Middle TN). Also, I know that rebuild can be quite expensive. So I started looking for other options. I found this: http://www.carmonkeys.com/1982-PORSCHE-PORSCHE-924-Engine-Assembly-924-Turbo-5-Years-Warranty. Now, I'm not sure what the price for a swap would be, but I'm thinking that the rebuild versus the buy and swap should be similar. and the purchased engine has a 'warranty' (for whatever that is worth). So the question is, what should we do? Rebuild or buy and swap? One other advantage to the buy and swap is that we now have a full (well mostly) engines-worth of spare parts...
Thanks for your time and your input. This is going to be a long process and I'm just trying to get a feel for the enormity of the mountain I have set out to climb...
1982 Porsche 924 Turbo (931) | 2002 Ford Ranger Edge | 2004 Acura TL A-Spec
Step#1: Get it running. | Step#2: Everything else. Simple.
PostPosted: Mon Dec 29, 2014 1:34 am    Post subject: Reply with quote
Welcome to the board, thanks for the desire to save another 931.
From a purely financial viewpoint, you should be able to find a running 931 for the price of those $4,000 used motors.
If you can do the rebuild yourself you will be further ahead in reliability and cost than installing a used motor.
Timing belt failures almost always cause 4 to 5 valves to be bent if the car was idling, more if at higher RPMS.
cahillsm
PostPosted: Mon Dec 29, 2014 2:50 am    Post subject: Reply with quote
Thanks for the welcome. While in a perfect world, I'd love to do a complete tear down, sandblast, re-lube, and re-assemble with new seals and replace or repair all the worn or damaged parts, I have neither the space or the equipment for such an undertaking. I have done a complete tear down and rebuild, in college, ah those were the days... But now I don't have open access to a workshop or the tools as I did back then.
But back in the real world, I think that a valve job might be enough to get this thing running (if there was no damage to the pistons...). It was running just before the timing belt debacle. I've found the numbers for some local shops, so perhaps they will be able to help. Looks like I need to remove the valve cover and head (possibly) to see exactly what I'm dealing with.
If we decide to get another car, we've decided it should be a late-80s 924S instead. It has "better" 944 components (many appear to be the same as the '82 931 appears to share many powertrain parts with the 944 already), no turbo (I'm a NA fan all-around), and that 924 shape that we love.
PostPosted: Mon Dec 29, 2014 3:52 am    Post subject: Reply with quote
Well, I've done both, a lot. The 2.0L lump is going to be cheaper to fix, not as many seals and gaskets as the 2.5L. My '80 924 Turbo has had a similar bad-luck history as yours! Three engines, and one more this summer. Here's my '88 924S when I bought it, nice eh?
Not so nice when I pulled the engine:
But, over a thousand dollars later (no rebuild, rebuilt turbo head, and lots of gaskets and seals).
So, choose wisely~!
PostPosted: Mon Dec 29, 2014 5:12 am    Post subject: Reply with quote
Not sure a 924S is 'better'. Certainly will be more susceptible to chassis rust than a '82 turbo. Belts cost a lot more to change along with the water pump. Etc.
Get the turbo head off and inspect. A head rebuild isn't too hard or expensive especially if you get a donor head for replacement valves
PostPosted: Mon Dec 29, 2014 5:24 am    Post subject: Reply with quote
Removing the head on a 931 with the engine in the car is complicated by the exhaust connections from the exhaust manifold to the turbo and exhaust manifold to the J pipe to the wastegate.
These connections are usually rusted and very easy to strip or break.
That said, removing the head is covered in other posts on this board and can be done with normal tools and skills.
It will cost you nothing but some skinned knuckles to remove the head yourself and see what you have.
kcoyle
PostPosted: Mon Dec 29, 2014 10:06 am    Post subject: Reply with quote
+1 to the above, try to get the head off yourself and see what's up. You will have to remove a ton of crap but at least you can get an idea of what its like working on these cars. Personally I would pull the motor if I were serious about getting this car running well as it would be easier in the long run if you factor in what Paul said about broken exaust/turbo connections, leaky oil pan gasket, oil pump gasket, turbo connection leaks, etc. These gaskets are relatively cheap but a PITA if not impossible to replace in the car.
OR, you can still pull the old motor and drop in this one in.
http://lexington.craigslist.org/pts/4814206700.html
IMHO if you will not be doing the mechanical work yourself the shop cost will be crippling, and the 4k engine with warranty sounds nice but the reality is that you don't really know (nor does partsmonkey)what your getting until you buy it and put it in.
Here are a couple of relevant threads if you haven't already read them.
http://www.924board.org/viewtopic.php?p=353668&sid=cd68770e3031e253ae2e965a1ce3ca74
http://www.924board.org/viewtopic.php?t=33026&postdays=0&postorder=asc&start=0
And the overflow tank is the least of your worries!
http://www.924board.org/viewtopic.php?t=35048&sid=44eabfa59112fb6cf3efd67bbd085849
PostPosted: Mon Dec 29, 2014 10:28 am    Post subject: Reply with quote
Head can be removed with both the intake and exhaust manifolds in place once the 3 bolts that hold the turbo onto the exhaust manifold and the 2 bolts that hold the top of the J pipe onto the exhaust manifold are removed.
Once these 5 are out, it's an hour job to do the rest.
PostPosted: Mon Dec 29, 2014 4:50 pm    Post subject: Reply with quote
Carrera RSR wrote:
924S. . .more susceptible to chassis rust than a '82 turbo.
Huh?
PostPosted: Mon Dec 29, 2014 6:17 pm    Post subject: Reply with quote
Huh?
Here in the UK we are seeing more 924S (and more so 944's) having serious sill and nearby areas rotting out than on earlier 924's. It's like the galvanising was better on early 924's than later.
cahillsm
PostPosted: Tue Dec 30, 2014 11:58 am    Post subject: Reply with quote
Thought I should upload some photos of "the beginning." You'll note the replacement distributor system (along with many other things I'm sure). The original system was replaced due to the unavailability of the crack position sensor which had gone bad.
Apologies for the blurry photos.
Engine Bay
Exterior
Interior
PostPosted: Tue Dec 30, 2014 4:15 pm    Post subject: Reply with quote
I say worth fixing, especially as it has been in your family so long.
