Brakes
Jamie_924
PostPosted: Tue Nov 04, 2014 6:32 am    Post subject: Brakes Reply with quote
Hi guys,
After some advice on brakes! On standard setup what discs's and pads are you using on track?
May be a weird question but new to the world of 924's
Cheers
Cédric
PostPosted: Tue Nov 04, 2014 7:21 am    Post subject: Reply with quote
Ive been using hawk hp+ most of the time, both on the na and then turbo. Woks well, good bite, never fades, and cheap. Dont forget good brake fluid like motul rbf 600. Its also very important to refurbish the calipers so they slide freely. Then you should be able to do hours and hours of fun track time!
´80 924 Turbo
Do you mean front disc/rear drum, or vented for wheel disc?
Jamie_924
PostPosted: Tue Nov 04, 2014 8:25 am    Post subject: Reply with quote
Thanks Cedric my fronts have been fully stripped and acid bathed and will most definitely be using high performance fluid
Front discs and standard drum setup on the rear its on a lux
PostPosted: Tue Nov 04, 2014 8:30 am    Post subject: Reply with quote
FWIW, the rear drum setup is less than super fun on the track, and quite easy to get rid of. You might consider upgrading rather than investing in it.
Jamie_924
PostPosted: Tue Nov 04, 2014 8:32 am    Post subject: Reply with quote
Unfortunately it is a requirement in the race series the car is going in. Must be as standard, im a Porsche tech by trade and converting to S 5stud setup was first on the list until I read tbe regs of te series
PostPosted: Tue Nov 04, 2014 8:54 am    Post subject: Reply with quote
Yikes.
Well, you might look into custom shoes, unless you enjoy adjusting your hot drums between sessions.
What series are we prepping for?
Jamie_924
PostPosted: Tue Nov 04, 2014 9:02 am    Post subject: Reply with quote
Tell me about it, not idle but hey ho!
Toyo tyres Porsche championship bud, cars in prep stages at the mo, was an old customers car but been stood for 3+ years, still in good nick mind
Cédric
PostPosted: Tue Nov 04, 2014 9:06 am    Post subject: Reply with quote
I didn't have any troubles with the drums during my na years performance wise. Not even in endurance racing. But its annoying to keep adjusting them, which you will have to... Otherwise they will drag(overheat) or have to much play.
´80 924 Turbo
PostPosted: Tue Nov 04, 2014 10:08 am    Post subject: Reply with quote
Read the regs, "as standard" makes no sense to me in this context, because many, many 2.0 cars were sold with four wheel disc. Does this mean if you start with a chassis that came with rear discs you have an immediate advantage over the guy next to you?
I doubt this is the case...certainly worth verifying with the sanctioning body.
emoore924
PostPosted: Wed Nov 05, 2014 12:51 pm    Post subject: Reply with quote
I agree. Most sanctioning bodies allow change of a car within class *if* the part being added/changed/removed means the car stays in class. For example, if a 924 with rear drum brakes is classed ITB and a 924 with rear disk brakes is classed ITB, you can switch between disk and drum without penalty.
Can't speak for your sanctioning body of course. You'll have to check that for yourself.
Qik Nip
PostPosted: Sat Feb 28, 2015 5:23 am    Post subject: Reply with quote
Portenfeld sells a matching 924 front pad, rear shoe in thier R4 (race) compound. Here's a link to thier website.' www.porterfield-brakes.com.
Rick
'79 NA 924 Land Speed Car
KDJones2000
PostPosted: Sat Feb 28, 2015 12:20 pm    Post subject: Reply with quote
Rick
I used a set of R4E's on the rear of our stock '78 NA for two 24 hour races plus 3 7 hour enduros. Never had to adjust them during the race, and not much even after the races.
They actually stopped pretty darned well for drum brakes...
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
