Posted: Fri Jan 16, 2015 3:06 am Post subject: |
Is it running? _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
Posted: Tue Jan 20, 2015 1:21 am Post subject: |
Hell yeah, needs front end aligned (plus this requires tearing down the control arms as I believe I didn't install the bushing all the way. They need to be pressed on don't they.) It needs a tune I still need to get a afm wide band set up to fill the hole I made for it in dash. But yeah it starts, charges, cools itself, revs, shuts down and restarts, lights work (blinkers need wired to new tree you know the blinker wiper on /off thingy under steering wheel.) and gt headlights need finished. Though yes sir it runs good wur works like it should injectors spray cone. Another pita though, oil pressure Guage was leaking at back of cylinder. head so I applied sealant and now the tube is plugged must of used to much. But again yeah it runs strong has a new clutch and motor rebuild. Hey I see the road. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
