My 924 Turbo, finally out on the road !
Goto page Previous  1, 2, 3, 4, 5 ... 9, 10, 11  Next
CÚdric
PostPosted: Sun Jun 26, 2016 9:44 pm    Post subject: Reply with quote
The wheel in the link doesn't seem to be an exact replacement, at least not if you look at the part numbers. But yes, since the wheel i have have a small dent i will change the wheel, and it will be a billet impeller, more info about that later this week if the starting price wasn't so high i would design a custom wheel together with some colleagues. But funds only allow of the shelf stuff..
┤80 924 Turbo
PostPosted: Mon Jun 27, 2016 12:45 am    Post subject: Reply with quote
Will be following what you do with the compressor impeller. Will want to do the same on my 931.
red 924 and not red 924
CÚdric
PostPosted: Thu Jul 14, 2016 9:31 pm    Post subject: Reply with quote
Turbo work is ongoing at a slow pace..
I have been installing a schroth clubman asm harness, finally! So now i can easily switch between std belt and harness depending on use. I have actually driven the car a bit as well, and it's still such a fun car, cant get enough even after all these years
┤80 924 Turbo
PostPosted: Thu Jul 14, 2016 11:12 pm    Post subject: Reply with quote
scrot
What about that billet compressor wheel?
CÚdric
PostPosted: Fri Jul 15, 2016 2:07 am    Post subject: Reply with quote
I will order it soon, had some trouble with the axle, the 2470 turbine shift is shorter than the later ones. Although it has the same part number in the kkk catalogue. Will have to trim the wheel a bit to get enough room for the compressor nut.
I have lots of things to do with the new house, so car stuff is going slooow. Even though I have 6weeks of vacation this summer, it's still not enough.
┤80 924 Turbo
PostPosted: Sat Jul 16, 2016 1:43 am    Post subject: Reply with quote
CÚdric wrote:
Intercooling plans are set aswell, inspired by a fellow forum member who did what I think is the nicest and most stealth way to install an IC, Im looking at you fasteddie
Thank you
CÚdric
PostPosted: Wed Aug 31, 2016 7:07 pm    Post subject: Reply with quote
Went over to Joakims garage to check out his car (The 440hp 924 turbo) and also buy is old intercooler, the end tanks looks crap flow wise(designed to clear a 951 radiatior, which suites me perfectly), but it worked well when he ran about 400hp, so should be fine for my low power levels, i can probably live with the added pressure loss since im going up in compressor size.
Which decade will this be installed? Who knows, i still have the clutch issues, which drags this project down..
┤80 924 Turbo
CÚdric
PostPosted: Thu Sep 01, 2016 4:35 pm    Post subject: Reply with quote
Seems to fit fine with my alu radiator, will probably be a pretty high performing cooling package..
┤80 924 Turbo
PostPosted: Thu Sep 01, 2016 7:01 pm    Post subject: Reply with quote
Oh nice, i have to do this on my red 924 as well as the cooling system is at its limit. I cant hold it at high loads for long unless its a cold day.
CÚdric
PostPosted: Thu Sep 01, 2016 10:57 pm    Post subject: Reply with quote
It has been ok for a couple of years (im talking about track driving now, street is never a problem), but the last outings I have been struggling a bit. Changed thermostat, fan thermostat and bled multiple times but cant really come back to were I was before. My radiator is in pretty bad shape so I thought it was time to change it, and since im planning on more power and an IC that is blocking the flow I thought its time for something bigger aswell.
┤80 924 Turbo
PostPosted: Thu Sep 01, 2016 11:20 pm    Post subject: Reply with quote
I need to upp the cooling performance of my IC and while i'm there i might just as well replace the radiator...and while i'm there i might just as well replace the clutch.
WEASEL149
PostPosted: Mon Sep 05, 2016 6:57 pm    Post subject: Reply with quote
Rad and intercooler look good.
How thick are the cores?
1979 UK 932
PostPosted: Mon Sep 05, 2016 7:07 pm    Post subject: Reply with quote
Rad is the same as mine Wes, circa 56mm from memory.
WEASEL149
PostPosted: Mon Sep 05, 2016 7:37 pm    Post subject: Reply with quote
Perfect then
1979 UK 932
CÚdric
PostPosted: Mon Sep 05, 2016 10:54 pm    Post subject: Reply with quote
How long have you been running that rad? Is it robust? That's my only concern, welds are pretty brute, but seems pretty good value for what you get.
┤80 924 Turbo
Page 4 of 11
