zubair
Posted: Sat Aug 04, 2018 7:11 am Post subject: porsche n/a 924 transmission swap |
hi guys i have porsche 924 n/a 1981 and am swapping in an audi/vw 1.8T because my motor was blown when i baught the car and parts are expensive and difficult to get in South Africa. i wanted to know if there are any bolt in transaxle upgrades i can make. if i get a 944 transaxle what will all need to be changed and is the any bolt on option looking for about 300hp max _________________ zubair solomon |
Joined: 08 Jun 2010 Posts: 994 Location: Maysville, Colorado
Posted: Sat Aug 04, 2018 11:42 pm Post subject: |
944 has a larger input shaft so get the torque tube also. The shift linkage should be the same, but if it's available you might get it also. Someone else will have to comment about the clutch disc. Check the engine swap section there have been several. _________________ Mike
'77 924
cricketdesigns.com |
Joined: 01 Oct 2004 Posts: 15511 Location: Woodstock IL
Posted: Sun Aug 05, 2018 11:03 am Post subject: |
A Bronco II clutch disc will work...has right spline arrangement for the larger 944 driveshaft. _________________ 75 Fiat X1/9 | 80 US 931 '941' | 78 Poli-Form |
zubair
Posted: Mon Aug 06, 2018 5:00 am Post subject: |
at the moment i have the standard transaxel in but i just wanted to know if there is anything i can directly swap that is stronger _________________ zubair solomon |
