jhattie
Joined: 29 Jul 2013 Posts: 40 Location: Yarmouth NS Canada
Posted: Tue Aug 05, 2014 9:04 am Post subject: Fuel Leak, |
Anyone have this issue?
My 82 N/A 924 seems to have a fuel leak up above the fuel pump, I've checked the pre-pump seems fine and so does the fuel pump, yet when the car is running there is a steady drip almost a slow pour even.
Thanks for any help
James _________________ 82 924
04 Avant Ultra Sport Wagon 1.8T
07 Rabbit
lot of Jetta's |
KDJones2000
Posted: Tue Aug 05, 2014 9:41 am Post subject: |
Sounds like a leaky fuel pressure reservoir. There should be one or two of them up above the fuel pump. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
jhattie
Posted: Wed Aug 06, 2014 8:55 am Post subject: |
I will look when I get it up on the lift, Thanks for the info. _________________ 82 924
07 Rabbit
lot of Jetta's |
deborah5123
Joined: 03 Aug 2014 Posts: 20 Location: Waterford, MI 48328
Posted: Wed Aug 06, 2014 3:36 pm Post subject: fuel leak |
| You must check your pump or any tubes that may cause the leaking. Better prevent the leakage from getting bigger. |
