1979 931 build
Goto page Previous  1, 2, 3, 4, 5, 6
BTRacing
PostPosted: Thu Jan 05, 2017 1:44 pm    Post subject: Reply with quote
Thank you !
Roof panel will be replaced with no sunroof fiberglass panel.
Tip: make sure that your tube notching is very tight.
Spend the time to fit them as close as possible. It takes a while but it is easier to fill the gap and will give you stronger joint.
Make sure that your heat is set right,practice on the scrap piece of tubing to set the welder right.
Take your time.... Cage is your safety.
www.btr-chicago.co
1977 924 Martini
1979 931 GTR Le Mans replica to be
2017 GMC Canyon Denali daily driver
PostPosted: Thu Jan 05, 2017 11:14 pm    Post subject: Reply with quote
Such a nice job.......with beautiful welds. Bravo!
PostPosted: Fri Jan 06, 2017 4:30 am    Post subject: Reply with quote
great project!
Do you have more info/ pictures on the sunroof delete conversion ?
937 DITC
PostPosted: Fri Jan 06, 2017 5:17 am    Post subject: Reply with quote
+1 one on that
tigging a cage, nice!! ...and your fitment of the tubes also very nice
PostPosted: Fri Jan 06, 2017 4:06 pm    Post subject: Reply with quote
Think I spy a late rad support in there...
BTRacing
PostPosted: Fri Jan 06, 2017 11:40 pm    Post subject: Reply with quote
Yes it is late model radiator support. First idea was to run 944T intercooler with GTS intake, but I think I want to build a larger ,custom intercooler that would look closer to original.
www.btr-chicago.co
1977 924 Martini
BTRacing
PostPosted: Sat Jan 07, 2017 1:03 pm    Post subject: Reply with quote
Just got my fiberglass roof panel. Pretty good quality. I will post some fitment pictures next week.
www.btr-chicago.co
1977 924 Martini
PostPosted: Sat Jan 07, 2017 4:44 pm    Post subject: Reply with quote
Do you have a picture of the front of the roof above the windscreen ?
Where did you cut is the roof in the front ?
thanks!
937 DITC
BTRacing
PostPosted: Sun Jan 08, 2017 7:59 am    Post subject: Reply with quote
Some of you asked about pictures of roof removed ,here they are
www.btr-chicago.co
1977 924 Martini
BTRacing
PostPosted: Sun Jan 08, 2017 8:01 am    Post subject: Reply with quote
www.btr-chicago.co
1977 924 Martini
PostPosted: Sun Jan 08, 2017 5:34 pm    Post subject: Reply with quote
Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar?
937 DITC
PostPosted: Sun Jan 08, 2017 6:48 pm    Post subject: Reply with quote
Dutch924-racer wrote:
Great, many thans!
No cut at the a pillar. Just a 'join'. Grind back to expose spot welds and joins.
Page 6 of 6
