bradelporsche
Posted: Sat May 31, 2014 3:26 am Post subject: OEM 924 2.0l Valve Spring specs |
Does anyone have the stock OEM valve spring values for max seat pressure etc?
My machinist wasn't able to find anything. |
bradelporsche
Posted: Tue Jun 10, 2014 9:34 pm Post subject: |
I`m unsure if they would physically fit without comparing dimensions, but the seated pressure is around double that of stock springs IIRC.
Unless you are running a fairly radical aftermarket cam and your cam manufacturer recommends those high pressures they will only lead to exaggerated cam & lifter wear, which is a major issue with these engines anyway. _________________ World`s quickest 924 2L slushbox
| Allan @ DTA wrote: | | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
bradelporsche
Posted: Wed Jun 11, 2014 3:24 am Post subject: |
That's what I thought.
I have a webcam grind #144 and they recommend running on stock springs. |
