SpeedyG
Posted: Fri Apr 11, 2003 5:06 am Post subject: 924 3,0L 16V ???? |
Hello,
Does somebody know if it is possible to put a 944 S2 engine into a 924S.
My engine broke down and now I'm thinking of putting a 3,0 16v from the 944 S2 into my 924 S
78porsche924
Joined: 14 Dec 2002 Posts: 1217 Location: Newark, DE(near where DE,MD and PA meets)
Posted: Fri Apr 11, 2003 5:36 am Post subject: |
| I dunno if you can, but that would be sick if you did. That thing would fly. Hope it does for your sake. |
Posted: Fri Apr 11, 2003 6:25 am Post subject: |
yes, it will work it has the same motor mounts as the 924s/944 engine, you will need the comp and probably the updated engine loom though, and maybe the tranny to hold the extra power _________________ 3 928s, |
AppleBit
Posted: Fri Apr 11, 2003 8:55 am Post subject: |
for the amount you are going to spend, you might just want to rebuild the engine you have.
But yeah, it's possible... The early 924's engine bay would need to be opened up. I think in 1979 they opened it up bigger for the turbo 924 models. |
Posted: Fri Apr 11, 2003 9:04 am Post subject: |
| AppleBit wrote: | for the amount you are going to spend, you might just want to rebuild the engine you have.
I don't think the bay changed at all from 78-80 _________________ 3 928s, |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Fri Apr 11, 2003 2:03 pm Post subject: |
the last european car had a small article about a guy who did that to a 924. _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
1982Porsche924
Posted: Fri Apr 11, 2003 2:41 pm Post subject: |
My bad, it was a 944S engine into a 924 turbo, anyways, i typed the article.
"Porsche 944s cost a lot more 10 years ago than they do now, which meant this swap seemed like a good idea at the time. John Harris, who had four 924s in his family bought this 924 Turbo new in 1980 and maintained it well. It was special to him. One day, it wouldn't pass its smog check. Whether the mechanic was shady or incompetent was never revealed, but his pognosis was a new turbo, fuel distributor and perhaps complete overhail or more would be required. Harris cast out for alternatives and came up with a low-milage 1987 944S engine. This newer, naturally aspirated mill was more powerful than the 924 Turbo and Harris decided it was the right upgrade. Unfortunately, it was far from a bolt-in swap. Porsche 924 and 944 engine mounts are different enough that the 944 mounts had to be welded to the unibody. A custom radiator was fabricated and mounted father forward , and quite a bit of plumbing and wiring was done before the car turned a wheel. Everthing was done right, done very carefully, with plenty of time taken to make it clean. Harris was pleased with the results even though he eventually installed the "junk" engine in his other 924 Turbo and found it was without fault. Today the 944S is not a super-expensive car to buy, and simply purchasing one would be easier, faster, and give better results, and probably cost less than this swap did. But though those are all factors to consider in any swap, the ultimate result is your own satisfaction. It's your car; do what makes you happy"
ow ow ow, my wrists hurt from the typing. _________________ 1979 Porsche 924 "S"
Eturbo924
Joined: 09 Nov 2002 Posts: 2212 Location: Londonderry NH
Posted: Fri Apr 11, 2003 9:53 pm Post subject: |
Yes it can be done and has been done. Excellence has an article on a 944S that changed to 944S2 motor. Also I know of a shop in Florida that has done this conversion 3 or 4 times. There is also a guy out west who is having his 924S 1988 changed to 968 motor. You need to change a bunch of things like wire harness, computers, exhaust, flywheel, clutch and such.
There is no issue with the compartment though. The air intake needs to be modified I believe though.
Eric _________________ 1982 924
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast! |
SpeedyG
Posted: Mon Apr 14, 2003 6:41 am Post subject: |
Thanks for the given advice. The engine I was looking for is an 1991 944S2 from a collision car (total loss), I am thinking about buying the complete car so all the stuf I wil need is still on the car.
I have forgoten to mention my own 924S is from 1986 so this should fit. |
RageLtMan
Posted: Tue Apr 15, 2003 12:24 am Post subject: |
The tranny from the s2 is the same as the standard 944? If so, then it looks like a great idea  _________________ 1987 924S 2.5L SOHC. |
titchati
Posted: Sat May 22, 2004 4:42 am Post subject: |
Hello !
Have a look at this
http://www.titchati.be/porsche/924S2.htm
See ya ! _________________ --------------------------
87' 924S for every day,
83' 924 for the track ! |
IanJ
Joined: 04 Sep 2003 Posts: 121 Location: Perth Western Australia
titchati
Posted: Sun May 23, 2004 7:17 pm Post subject: |
Hello !
Wow nice !
Yes I'm sorry I'm too lazy to write my website in english
See ya! _________________ --------------------------
IanJ
Posted: Sun May 23, 2004 7:46 pm Post subject: |
Don't apologise....the rest of us are too lazy to learn French
That is a very nice site. I just had a quick look (will definately use it for reference!). Which car is yours?
Have you taken your car to Spa yet? I hope to get there later in the year for a track day.
Ian _________________ It's only funny until someone gets hurt.....then it's hilarious! |
924guy
Posted: Sun May 23, 2004 9:18 pm Post subject: |
what a huge project....not exactly economical, but high marks on the cool factor!! I know of at least one 931 that underwent a suceessful 951 power train conversion, i think the guy was in Pennsylvania someplace.... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
